Road Meekatharra - Wiluna
Submitted: Tuesday, Feb 17, 2004 at 02:19
silvia
Would anyone know if the road between
Meekatharra and
Wiluna is okay to be crossed in a 2wd?
Am heading to Kalgoorlie once we leave
Newman and this is the most convenient looking access across to the Goldfields Hwy. Any suggestion would be appreciated =)
Reply By: Coops (Pilbara) - Tuesday, Feb 17, 2004 at 05:32
under normal conditions I believe so but currently there's a lot of roads that have been damaged or are closed from heavy rains. Check with Main Roads on that one.
They've got a pretty good websiteLive the life you love -
Love the life you live !!!
46995
Reply By: The Banjo - Tuesday, Feb 17, 2004 at 08:48
Check the www.vks737.on.net site .... there's a link at the front to a WA roads page
(maintained regularly by one of their members).I need red sand under me.
47004
Reply By: ExplorOz Team - David - Tuesday, Feb 17, 2004 at 11:39
Also read our Road Conditions it is updated at least twice a week. We use a lot of the info from the vks page and have our own government sources for all locations. Regards
Always working, not enough travelling ;-)
47025
Follow Up By: silvia - Tuesday, Feb 17, 2004 at 12:44
Thankyou to all =)
I went to the Main Roads site and it said that stretch of road was in the Kalgoorlie-Goldfields report, however when I went to that report it just had tourist info nothing on the roads.
The link on the
HF radio page to the WA roads wouldn't come up for me at all, will try again later.
I read through the Road Conditions report here at Exploroz. I am figuring it is in the area of report for the Nippon Highway and
Sandstone to get across to Goldfields Hwy but I am not sure so if someone could clarify that would really be appreciated. I have a Hema map and while it has lots of info on it it doesn't have the actual name of the stretch of road between
Meekatharra and
Wiluna so I'm not sure exactly what I am looking for.
We are going there mid March so hoping it will have cleared up but if the conditions are no good then will just find another way across!
Thanks for help so far is making my life a little less complicated =)
309004
Reply By: Member - Howard- Tuesday, Feb 17, 2004 at 12:59
If you are going from
Newman to Kalgoolie you can shortcut thru Canyu road to
Wiluna from south of Kumarina Motel/roadhouse.Saves about 180 Km from memory as you only do 1 side of the triangle.
some old maps I had showed it as a private road but in July 02 when we were going
Wiluna to
Newman learnt that council had taken over maintenance of road. it was excellent and definitely 2wd standard. You could always check condition with
Wiluna police station.
regards
Howard
47035
Follow Up By: silvia - Tuesday, Feb 17, 2004 at 21:31
Howard
I can see Canyu road marked on my map but it isn't marked private. I will call
Wiluna as soon as I find the number and ask the Question. Thankyou =)
309073
Reply By: Member - Bob - Tuesday, Feb 17, 2004 at 13:04
Five years ago it was a magnificent wide dirt freeway.Bob
47037
Reply By: Member - Fred - Tuesday, Feb 17, 2004 at 13:48
If you want bitumen the road from
Mount Magnet through
Sandstone is now sealed
Last time we did
Leonora,
Wiluna,
Meekatharra was in commodore with no trouble - look out for stone throwers in
Wiluna
47050
Follow Up By: silvia - Tuesday, Feb 17, 2004 at 21:34
My map is 02 and shows portions past
Sandstone -
Wiluna still unsealed. It's an extra 200km but if I am not sure of the other roads it's not much of a deviation to avoud getting bogged somewhere in the 2wd. Or maybe I should buy me a WRX =D =D
309074
Reply By: Alex H - Tuesday, Feb 17, 2004 at 20:42
G'day,
if you are coming from the south cut through
Sandstone from
Paynes Find - its dirt, but a much better road in my experience than the
Meekatharra-
Wiluna road
Alex
47110
