Cub camper water tank
Submitted: Monday, Jan 20, 2014 at 21:16
ThreadID: 105881 Views:6291 Replies:3 FollowUps:1
Hey there
Recently purchased a second hand cub camper and can not open the water tank, it unlocks but then spins, just wanted to check how it actually opens before applying a lot of force!
Thanks in advance
Reply By: MEMBER - Darian, SA - Monday, Jan 20, 2014 at 21:21
Once unlocked, push it in quite firmly and then turn it anti-clockwise.
AnswerID: 524825
Reply By: exmouth1 - Monday, Jan 20, 2014 at 22:44
G, day Amanda,
My cub water tank cap spins when locked, unlock then push in and turn, it can be quite stiff to turn anticlockwise.
Cheers john
AnswerID: 524828
Follow Up By: Member - Leanne W (NSW) - Tuesday, Jan 21, 2014 at 08:30
Hi John,
I was having the same problem as Amanda with the water tank cap on my Aussie Swag camper trailer. We don't use it very often so when I used it last week I just assumed that it was unlocked when it was spinning freely. Just went out and did what you said and hey presto, cap came off! Like yours it was quite hard to turn anticlockwise.
Thanks heaps!
Leanne
ps I hope this works for the op too.
FollowupID: 806694
Reply By: Member - Frank P (NSW) - Tuesday, Jan 21, 2014 at 08:22
If the issue is a rubber seal on the cap sticking to the filler in the CT, as it is with mine, a spray of silicon based lubricant (from Bunnings or other hardware stores) or better if you have it, a light smear of silicon-based O ring grease works wonders.
Vaseline would also work, but can affect some types of rubber.
AnswerID: 524836
