yaesu FT 900 whith antenna codan 9350
Submitted: Saturday, Jan 25, 2014 at 04:34
ThreadID: 105942 Views:6054 Replies:2 FollowUps:1
Dear if anyone can help me I have a yaesu ft 900 and I want to connect it to an antenna Codan 9350 but I can not get it to work via the 5-pin tuner minidin of that apparatus could you help me with a wiring diagram to match the system iv3ezz thanks ivan.
tank you so mucth to evrithing
e-mail iv3ezz@gmail.com
Reply By: Life Member - Fred B (ex-NT) - Saturday, Jan 25, 2014 at 09:25
suggest you contact the HF Radio Club
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 525079
Follow Up By: Member - LeighW - Saturday, Jan 25, 2014 at 10:53
The autotune will use a priority interface setup, ie designed to work with their codan transceivers, same as Barrett with their autotuners.
You can however get an adapter for instance to adapt the Codan to a ICOM transceiver.
You maybe able to get similar for your radio but have never looked myself.
As for wiring info, I would contact Codan and see if they will supply the info or a search of the internet for schematic for codan antenna xxx may return some info as these would be used by many amateurs for their rigs.
FollowupID: 806956
Reply By: Echucan Bob - Saturday, Jan 25, 2014 at 17:15
Ivan
I've got an adapter for the FT857D to the Codan 9350. There is a guy in WA who makes them but I have no record of his details. They appear on eBay from time to time.
The Yaesu pinouts are on page 13 of this manual.
9350 Antenna Control Cable
15 pin D 6 Pin Mil. Connector Configuration
12, 13 A +12VDC
14,15 B Gnd
4 C Tune
5 D Scan
11 E Tuned Indicator
- F Not Used
AnswerID: 525108
