common rail fuel systems
Submitted: Monday, Feb 10, 2014 at 08:59
azzman
Hi everyone, I was wondering if anyone has any info on releasing
fuel pressure safely on high pressure side of high pressure
fuel pump so I can remove
fuel lines to access intake manifold and valve cover on my mitsubishi triton. It's a ml 3.2 did.
Reply By: Notso - Monday, Feb 10, 2014 at 11:05
I had one of these and have a manual pdf version. This was available on the Newtriton
Forum here:
New Triton Forum
REMOVAL SERVICE POINT
FUEL HOSE D DISCONNECTION
CAUTION
When disconnecting the
fuel hose D, the
fuel pressure in the
fuel line is high. Thus, wait for 3 minutes or longer after the engine is stopped, and cover the
fuel hose D with a rag or similar materials to prevent the
fuel splash, and then disconnect the
fuel hose D.
526127
Reply By: Racey - Monday, Feb 10, 2014 at 14:15
If you are removing the HP
fuel lines, becareful, a lot of these fitting are not re-usable. No sure sure about the mitsubishi.
526136
Follow Up By: Ross M - Monday, Feb 10, 2014 at 15:48
Also, any reference to
fuel hoses isn't going to be 20,000psi either. Steel lines yes, but not a hose.
808310
