Monday, Mar 03, 2014 at 20:45
Hi Johno,
Obviously, some tyres are softer than others & wear very quickly.
The Bridgestones that came with my last 2 new Utes are pefect examples!
I tow a dual axle work trailer with very heavy loads, day in, day out. I also tow a single axle CT when I go away. The work trailer weighs around 400kg when it's empty, just carrying tools (chainsaws, leaf blower,
fuel cans,
First Aid Kit, chaps, PPE, yadda, yadda) The CT weighs around 700kgs when loaded, BUT the dual axle work trailer is MUCH harder to take off from a standing start with, even when empty. The difference between the single axle & dual axles of my 2 trailers is simply HUGE, but I need the carrying capacity of the dual axle for my work.
Keeping tyre pressures up around 40 psi on the work trailer certainly helps, but the rear Bridgestones on my last Ute wore out at around 17,000kms & I'm very much an old man when driving.
I put Goodyear AT3's on my last Ute after the Bridgestones wore out & they did quite
well by comparison. They had around the 42,000km mark on them when I traded it in & were still quite good. Same daily workload & touring as the Bridgestones, but they were just simply more durable. I didn't notice ANY difference in performance between these 2 brands doing what I do with the Ute.
I'm thinking of putting Toyo's on this Ute when the Bridgestones wear out, but I'm still very undecided. The Bridgestones currently have 12,000km's on them & are showing very obvious signs of wear on the rear
wheels.
Others will have different experiences to
mine I'm sure, but my Ute tows big loads everyday & is probably an extreme case.
Hope this was of at least some help!
Kevin.
527599
Follow Up By: johno59 - Monday, Mar 03, 2014 at 20:57
thanks Kevin. It was a help. Thought I was the only one having rear tyre excessive wear. johno
810028
Follow Up By: Darryl E - Monday, Mar 03, 2014 at 23:36
Hi i have a T31 x trail and at times pull single axle car trailer ( all up about 1 tonne) long distances, eg 5000km round trip x 2 last year. So about 40% of yearly work is as a tow vehicle.
I will get 40 thousand out of the tyres, maybe more .. these are the originals. I rotate every 10 and it looks as if the fronts are wearing a little more than rears... as i would expect as i am in front wheel drive 98 % of the time , even though it is the diesel 4WD version.
The trailer with small car , i ensure carries its weight just forward of axles etc keeping a medium to light weight on towball, i do however fit tow levellers. The car is usually reasonably
well laden on the long trips as
well
I do these stints in long stretches though, so not a lot of stop and go stuff, which would put more stress on the rears.
So i don't emulate your experience., just to let you know
810042
Follow Up By: KevinE - Tuesday, Mar 04, 2014 at 09:00
I hear ya, but I haven't been able to get any reasonable wear out of the original tyres on the last 2 Utes I've bought.
Mine is all city driving with the work trailer empty on the way to a job & mostly with a felled tree in it after the job is done (2.5T + is not unusual).
I put all of the heavy logs in the back end of the trailer to minimize ball weight where I can.
I never had this issue with the previous Ute which came with a different brand of tyres. They lasted very
well doing the same work.
810049
