Ctek MXS 10 vs MXS 15
Submitted: Monday, Mar 03, 2014 at 20:48
Tate1984
Hi all,
I looking for a charger for my 260Ah 12v AGM battery bank and can't decide which Ctek charger would be the best.
The MXS15 specifies it is designed to charge battery banks 30-300Ah and maintenance charge up to 500Ah.
The MXS10 can charge banks 20-200Ah and maintenance charge up to 300Ah. It also appears to have a charging program specifically for AGM batteries whereas the MXS15 doesn't.
Does the advantage of having a specific AGM charging program out weigh the higher charging rate of the MXS15? Will the MSX10 be able to charge the 260Ah bank sufficiently?
Any input would be appreciated.
Reply By: Nomadic Navara - Monday, Mar 03, 2014 at 21:01
For a 260 Ah battery I would be looking for something with a 25 A output or larger.
527601
Follow Up By: Ross M - Monday, Mar 03, 2014 at 21:17
My thoughts exactly.
With a 260AH pack 1/2 discharged the recharge time even with the 15amp is around 9 hours if all is
well. At least 13hrs with a 10amp device.
810029
Follow Up By: Tate1984 - Monday, Mar 03, 2014 at 21:54
Thanks guys. I thought 10 amp sounded too small. Ctek also have a 25amp model but similar to the 15 amp, no AGM charge program.
Any recommendations on other brands?
810036
Reply By: HKB Electronics - Monday, Mar 03, 2014 at 23:11
If you consult the manuals you'll find the 15A versions charges at 14.4V and the 10 version charges at 14.4V (AGM) their the same!
As the others wrote, bigger is better.
Leigh
527611
Reply By: ABR - SIDEWINDER - Tuesday, Mar 04, 2014 at 11:37
Hi Tate
I would go for a 25A charger, general rule is 10% of capacity with 20% of capacity being the ideal.
Our ABC1220D will do max of 400ah, The ideal charger would be our Pro-Series 40A charger, what is your charging requirement. IE: Time, how and when will you need to use the charger.
Derek from ABR
527626
Reply By: ChristaJezz - Sunday, Mar 09, 2014 at 19:26
I went the 25amp Ctec for a 120Ah deep cycle AGM after going through everything on the inter web. Very happy with charger. Got it from autoelecau on Ebay, cheapest I could find, no probs with delivery.
Jeremy.
527988
