T Van fridge size
Submitted: Tuesday, Mar 04, 2014 at 21:38
pling
We have just purchased a 2013 T van which has the fridge slide but no fridge.
The previous owner had an ARB 47 litre fitted.
Can it fit a larger fridge size?
Waeco 50 or bigger?
Please don't turn this into an Engle vs the rest as I have had two Engle's fail.
Reply By: Member - Rosco from way back - Tuesday, Mar 04, 2014 at 22:23
May I suggest you measure the size of the hole and go from there.
527662
Follow Up By: pling - Wednesday, Mar 05, 2014 at 03:34
Thanks for the help Rosco, unfortunately the van is in
Brisbane and I am in
Goulburn, otherwise I would have done that.
Thanks for the advice.
810107
Follow Up By: Member - Rosco from way back - Wednesday, Mar 05, 2014 at 09:41
No worries P, your additional info that you don't have access to the van puts your problem in a whole new light.
810115
Reply By: Member - Andrew L (WA) - Tuesday, Mar 04, 2014 at 22:29
Try asking here
http://www.tracktrailerforums.com/
527665
Follow Up By: pling - Wednesday, Mar 05, 2014 at 03:42
Thanks Andrew, will try that.
810108
Reply By: Member - Phil G (SA) - Tuesday, Mar 04, 2014 at 22:50
I think you'll find the ARB 47 litre is the biggest you'll get in there. The tracktrailer
forum posted above has more detail.
527668
Follow Up By: pling - Wednesday, Mar 05, 2014 at 03:43
Thanks Phil, will try that.
810109
Follow Up By: Member - Boobook - Wednesday, Mar 05, 2014 at 08:42
There is a discussion about this exact subject of the track trailers
forum. The result was
47lt ARB, 40lt Engel or the National Luna 50lt twin. Possibly a 60lt Waeco though the handles probably have to be removed and double check the height.
810114
