Comment: EOTreks Route Files
Submitted: Monday, Mar 24, 2014 at 14:44
Member - Marg G (VIC)
Is this a compatible format with HEMA NAVIGATOR6 EDITION?
Reply By: ExplorOz Team - Michelle - Monday, Mar 24, 2014 at 17:28
Yes it says it is in the product description (OziExplorer option).
BTW - your member image pic in your
Forum footer isn't working. I think you have a 6MB .mov file? That's video and not supported.
529010
Reply By: ExplorOz Team - Adele - Monday, Mar 24, 2014 at 17:29
Hi Marg G,
They certainly are. The
routes can be viewed using the EziOzi program on the Navigator (simply select the OziExplorer file format found in Buying Options). Once downloaded, you will need to transfer the files to the HN6's SD Card, then use the
routes menu to load them as needed for navigation.
529012
