Any problems with Nissan Patrol 2001 models
Submitted: Tuesday, Apr 15, 2014 at 08:53
ThreadID: 107289 Views:3650 Replies:4 FollowUps:15
We have been having some trouble with our 2001 Nissan Patrol. It loses power when accelerating hard from 90km/h to 100 km/h. Does anybody else have this trouble or know what it could be??
Reply By: Athol W1 - Tuesday, Apr 15, 2014 at 09:02
Dean
That sounds very much like a blocked fuel filter, does it also tend to loose power on hills.
Athol
AnswerID: 530586
Follow Up By: Dean V - Tuesday, Apr 15, 2014 at 09:15
Not really sure as we havent drove it on hills much i think once or twice. But we will know for sure on friday... Have you had the same problem?
FollowupID: 813522
Follow Up By: Athol W1 - Tuesday, Apr 15, 2014 at 09:57
Dean
As a retied mechanic I have seen this on numerous occasions.
Athol
FollowupID: 813526
Follow Up By: Member - cherrywipe - Tuesday, Apr 15, 2014 at 10:02
I have a 2000 4.2 patrol diesel. Recently had similar problem.
Problem solved by cleaning mesh filter on fuel pump , end of fuel line into pump.
FollowupID: 813527
Follow Up By: Dean V - Tuesday, Apr 15, 2014 at 10:07
Ours is a 01 4.0 Patrol Diesel. was yours dirty.
FollowupID: 813528
Follow Up By: MEMBER Bushbum - Tuesday, Apr 15, 2014 at 16:01
Dean I strongly suggest that you check the tiny mesh filter that is located under the banjo fitting on your fuel pump. it is not readily seen but if you get a cotton bud and gently push in into the pump after you undo the banjo fitting you will easily remove it. Be careful you do not loose the small spring that is also in there.
FollowupID: 813558
Reply By: bluefella - Tuesday, Apr 15, 2014 at 10:14
As said check 1. mesh filter on fuel pump, 2. change fuel filter, 3. change air filter.
Process of elimination or just replace all. That will rule out filtration as the problem.
AnswerID: 530593
Follow Up By: Dean V - Tuesday, Apr 15, 2014 at 10:23
Thank you we will try it.
Regards Dean :)
FollowupID: 813529
Reply By: Greenant - Tuesday, Apr 15, 2014 at 12:03
Dean
Could be as simple as a dirty MAF sensor. Try cleaning it with aerosol can of cleaner or contact cleaner from Jaycar. If you google nissan maf sensor there is lots of info on poor performance and cleaning
Let us know how you get on
Greenant
AnswerID: 530599
Reply By: Oldbrowny - Tuesday, Apr 15, 2014 at 13:46
I agree with the MAF diagnosis. Download and have read of this document from the Patrol4x4 forum. It describes your fault in detail.
http://www.patrol4x4.com/forum/zd30-di-engine-3-litre-71/gu-patrol-reference-bible-newbies-start-here-zd30-info-31418/
AnswerID: 530609
Follow Up By: pepper2 - Tuesday, Apr 15, 2014 at 16:41
i think he has a 4.2 not a 3 litre,not sure there is a maf unit in a 4.2.
FollowupID: 813560
Follow Up By: Robin Miller - Tuesday, Apr 15, 2014 at 16:55
I was thinking it could be a petrol also Pepper2 and then 2001 could be 4800 or 4500 - makes it prety hard to give advice without knowing even the engine type.
FollowupID: 813561
Follow Up By: Dean V - Tuesday, Apr 15, 2014 at 17:00
We have a 4.0 Diesel and its a 2001
FollowupID: 813562
Follow Up By: old patrol - Tuesday, Apr 15, 2014 at 18:23
I could be wrong but I didn't think that Nissan made a 4.0 Diesel?
FollowupID: 813569
Follow Up By: Dean V - Tuesday, Apr 15, 2014 at 18:28
yeah im pretty sure its a 4.0?!
FollowupID: 813571
Follow Up By: Robin Miller - Tuesday, Apr 15, 2014 at 18:29
There is no 4.0 diesel Dean
FollowupID: 813572
Follow Up By: Dean V - Wednesday, Apr 16, 2014 at 08:15
Yeah sorry guys its a 3.0 Diesel!!! I mucked up!
FollowupID: 813599
Follow Up By: Robin Miller - Wednesday, Apr 16, 2014 at 09:50
Ok Dean - look one thing I would say above all else is take the problem seriously , don't muck around , that car of that year is probably the most prone of all 4wd wagons to engine fail.
About that time the reports became overwhleming and Nissans first reponse was to give owners a dip stick with the oil level marked up higher so that the crank would take more oil (more splash on pistons).
From there it went downhill and today if you search around you will find much information under the heading "Anti grenading".
Its a very stressed engine with a complex control system that works really well when it works but a number of issues can cause ECU to get false info and over boost in an expensive flash.
Get it and the points others have raised here a check out and check all hoses for both leaks and particulate clogging ASAP.
I'd like to leave you with a least one positive comment and so one in our group is lovingly looked after and recently clicked over 500,000km.
FollowupID: 813604
Follow Up By: Bob Y. - Qld - Wednesday, Apr 16, 2014 at 10:01
carsales.com.au
FollowupID: 813605
