Comment: EOTrackMe
Submitted: Tuesday, May 06, 2014 at 16:13
Member - Roger S (QLD)
A couple of questions David:
iPhone app loads OK and appears to work but no track visible 'tho device is visible. No Live Tracking button.
uTrackMe 2
Beacon apparently not available for iPad on iTunes
How do I get uTrackMe to connect to Comm 3 (usb GPS input) on Windows OziExplorer please.
Thanks.
Reply By: ExplorOz - David & Michelle - Wednesday, May 07, 2014 at 13:54
Roger,
If you read the documents on the EOTrackMe Page for IOS it has a link to the current version of the
Beacon client - the iPhone one works fine on the iPad. So just install this follow the settings information and you should be up and running no problems.
If you PC is using a Garmin USB GPS then currently the answer is no go. Garmin use a private data messaging system and at this stage we have not written the client program to support the PVT protocol.
David
532044
Follow Up By: Member - Roger S (QLD) - Wednesday, May 07, 2014 at 18:04
Thanks very much. Questions answered and all OK now.Cheers.
815248
