Jayco Swan 2007 12 volt power supply isn't working
Submitted: Sunday, May 11, 2014 at 17:34
ThreadID: 107725 Views:4764 Replies:3 FollowUps:2
We have a Jayco swan outback, went away for a few nights we could only use the 12 volt for power. Worked the fist night got up in the morning turned light on and we lost all power. When we got home it will only start now when it is first plugged into main 240v power. When we unplug the power switches over to 12 volt but if we turn it off it wont turn back on again unless we plug back into mains.
Can anyone help us!!
Reply By: Member - Keith C (NSW) - Sunday, May 11, 2014 at 18:01
Hi, Sounds very much like a flat van battery, put it on a charger to bring it back up, was the frig on gas when you were camped? 3 way frigdes eat 12v.
Regards Keith
AnswerID: 532276
Follow Up By: Danny T4 - Sunday, May 11, 2014 at 19:48
HI no the fridge wasn't working either the regulator was buggered, and the battery was fully charged.
FollowupID: 815527
Follow Up By: Lionel O - Sunday, May 18, 2014 at 18:29
The van battery is NEVER connected to the fridge.
Van battery cuts out at about 10.5 volts. So flat battery would be the answer here.
regards, Lionel.
FollowupID: 816001
Reply By: The Bantam - Monday, May 12, 2014 at 09:16
Sounds very much to me like the battery has died.
Batteries that are on their last legs will rapidly come up to charge and show as fully charged but actually store very little energy.
If you don't have the ability to do it yourself..have your battery tested.
If the battery is over 2 years old, there is a pretty good chance it is due for replacement.....if it is over 5 years old you have done very well and should not feel you have in any way been short changed.
The other possibility is that the charger is not working properly.
AnswerID: 532321
Reply By: Rober B - Monday, May 12, 2014 at 19:11
The jayco has a main battery fuse located beside the main control panel check to see if it has blown
AnswerID: 532364
