2013 suspension upgrade
Hi All
Just had a 40mm, 0-300kg rear leaf spring, winch & bar rated front coil Tough Dog suspension installed on my 2013 DMax Dual Cab, for those that are interested here are the results.
I hope they may be of some help to others deciding on a suspension upgrade.
Stock Suspension
With no accessories, gear, passengers or trailer attatched (measured from bottom of rim up to gaurd:
Front passenger side.....755mm
Front Driver side..........760mm
Rear passenger side.....770mm
Rear drivers side..........767mm
Stock Suspension
With no gear, passengers or trailer attatched (measured from bottom of rim up to gaurd)
PLUS Steel Bar, Canopy, Winch, Drawer System.
Front passenger side.....745mm
Front Driver side..........750mm
Rear passenger side.....750mm
Rear drivers side..........755mm
So 10-15mm drop in front, approx 20mm drop in the rear.
Tough Dog Suspension
PLUS Steel Bar, Canopy, Winch, Drawer System, and Aux battery in tub.
Front passenger side.....790mm
Front Driver side..........790mm
Rear passenger side.....790mm
Rear drivers side..........790mm
So 25-30mm lift in front (from stock height), approx 20-25mm in the rear (from stock height).
No too bad a lift considering the extra weight.
With no passengers, approx 120kg gear in tub, trailer attatched (ball weight approx 110kg)
Front Driver side..........795mm
Rear passenger side.....760mm
Rear drivers side..........765mm
So 0-5mm lift in front (from stock), 5-10mm drop in the rear (from stock).
So after the 40mm lift the car when fully loaded (no passengers) and with the trailer hitched sits pretty much level (no appreciable rake from rear to front), the front has in fact lifted approx 40mm and the rear has dropped 10-15mm.
I was hoping to maintain a bit more height in the rear when loaded.
Having said that the car drives very well, much nicer than the stock suspension, less body roll and no nose diving on braking.
I think in retrospect i should have gone for the 300kg constant, which may have held the rear up a little better albeit at the cost of some comfort.
I will look into ways to stiffen the rear a little, maybe just another leaf, or maybe a SAX spring helper.
Dave
