Holden Rodeo Turbo
Submitted: Monday, May 19, 2014 at 14:50
ThreadID: 107845 Views:3676 Replies:3 FollowUps:3
Hi. I have a Holden Rodeo 2004 Turbo diesel. I need to replace the Intercooler as it has a crack in it. It has a very small amount of oil which looks like it has sprayed out. Can I just unbolt the intercooler and put the new one in. Is it that easy or do I need a mechanic to do it. Any help would be great.
Reply By: fisho64 - Monday, May 19, 2014 at 16:23
might be a stupid question but if you need to ask how to replace it Im guessing your also not sure exactly how it works and what the problem is?
Most TD's get a small amount of oil accumulating in the intake/intercooler, usually coming from the breather.
While yours may be cracked, its more likely just a split hose or loose clamp?
If it is the standard air to air IC, you can just unbolt it and bolt the new one in place, or repair your old one with kneadit maybe?
AnswerID: 532770
Follow Up By: Brian J12 - Monday, May 19, 2014 at 16:55
Thanks for the reply. When you look through the front grill you can see that the cooler has a split in it and that is where the oil has come out. I am pretty sure it is just an air cooler but thought someone could confirm this for me and that I could replace it myself.
FollowupID: 816069
Follow Up By: fisho64 - Tuesday, May 20, 2014 at 00:34
Isnt the Rodeo a top mount? may be wrong...
FollowupID: 816097
Follow Up By: Brian J12 - Tuesday, May 20, 2014 at 05:34
The cooler is mounted in the front of the radiator.
FollowupID: 816098
Reply By: 08crd - Monday, May 19, 2014 at 18:03
You may be able to get it fixed at a radiator shop. They can repair splits in radiator cores, so can't see why they couldn't have a look at your intercooler.
AnswerID: 532779
Reply By: Mogul - Monday, May 19, 2014 at 18:38
The early RA's had a recall for cracked intercooler's, worth checking with Holden to see if yours was done.
AnswerID: 532783
