Looking for lashing or d-rings
Submitted: Sunday, May 25, 2014 at 13:54
dreamerman
Have been looking to buy a few lashing or d-rings like in the pic. I only want a single bolt/screw down hole. Bunnings don't have it and those available locally online are with 2 or more bolt/screw down holes.
There are plenty overseas but due to its weight, shipping cost is a killer.
Any pointers will be appreciated.
Reply By: Athol W1 - Sunday, May 25, 2014 at 14:23
Dreamerman
I have a recollection of something similar to that being fitted to the cargo area of the later model Holden Jackaroo, so a visit to the local wrecking yard may prove beneficial.
Athol
533139
Reply By: Mikee5 - Sunday, May 25, 2014 at 14:28
Toyota Landcruiser wagon rear cargo area tie down points. From the wrecker. The rings are round but apart from that look the same.
533140
Follow Up By: Member - Frank P (NSW) - Sunday, May 25, 2014 at 14:50
Yep, Prado too.
816451
Reply By: Ozrover - Sunday, May 25, 2014 at 14:30
I got some that are similar, but sit on a plastic base from Alice bolt supplies, but I would guess that you would find then at any major bolt specialist or marine chandlers.
533141
Reply By: MUZBRY- Life member(Vic) - Sunday, May 25, 2014 at 15:43
Gday
Try UES 38/40 South Link rd Dandenong 03 8787 3100 or try that name in your state.
533143
Reply By: Bob Y. - Qld - Sunday, May 25, 2014 at 16:08
DM,
Have a look at Whitworths or Ovesco. Anything from Whitworths may be stainless steel, while Ovesco has both s'steel and nickel plated items.
533146
Reply By: phasar - Sunday, May 25, 2014 at 16:26
Ovesco 1073.06, should do the trick.
Peter.
533147
Reply By: MEMBER - Darian, SA - Sunday, May 25, 2014 at 16:31
A very common fitting in station wagons, especially 4WD (my Landcruiser and Jackaroo had them) - any decent wrecking yard should have heaps of them, but probably still in situ.... take some sockets with you.... commonly a 12 - 14mm bolt with a fat spacer underneath to elevate them above the carpet.
533148
Reply By: dreamerman - Sunday, May 25, 2014 at 17:45
Thanks guys, never thought of visiting wreckers!
533152
Reply By: rodnirene - Sunday, May 25, 2014 at 20:02
Hyundai iLoads have them, maybe 8 in each floor.
Rod H.
533162
Reply By: The Bantam - Sunday, May 25, 2014 at 22:21
Not quite like that, more d shaped, but close, comes with a plastic collar.
ankra part number 45545-15.
Most diesel & truck spares shops will have an ankra catalogue and may be able to get them in for you.
have alook in the catalogue whle you are there planty on interesting bits.
533168
Follow Up By: The Bantam - Sunday, May 25, 2014 at 22:23
BTW the ones you buy from ankra are rated.
working load restraint limit 350Kg
816493
Reply By: dreamerman - Saturday, May 31, 2014 at 22:31
Update: Bought 30 of these used from gumtree for less than $2 each. Heavy duty and solid. Sorted.
533521
Reply By: Freshstart - Sunday, Jun 01, 2014 at 07:35
A quick search on ebay using the text "tie down anchors" and I found heaps (110 results). One example is below.
Ebay tie down anchors
533527
Follow Up By: dreamerman - Sunday, Jun 01, 2014 at 11:26
Yes, tie downs are plentiful but I am only interested in single bolt-hole ones like the ones I picked up cheap.
816926
Follow Up By: Freshstart - Sunday, Jun 01, 2014 at 11:48
You mean these one that I found at about item 10 on that search. And no doubt there would be heaps more.
I will leave you to it then. I have the single holed ones as
Single hole tie downs.
816928
Follow Up By: Freshstart - Sunday, Jun 01, 2014 at 11:50
I understand that you have now purchased some. That's good. I missread your post to me. Cheers
816929
Reply By: dreamerman - Monday, Jun 16, 2014 at 14:10
Managed to screw in 19 tie-downs over the weekend. Used M5 rivet nuts. Will be fitting a Carryboy canopy this Sat.
Took the opportunity to spray Lanox on
the tub when I removed the liner. All good but smells bad.
534481
