Tuesday, May 27, 2014 at 21:26
Brian,
Out of Town used to be just west of
Newcastle, and they build the Long
Ranger line of tanks.
Had a HJ60 some years back and put an aux
tank on it. Can't remember what brand it was, but it was supplied with a twin filler fitting that replaced the original Toyota filler. The main filler was standard size, but the aux was probably only about 11/4", so took a little longer to fill. These 2 inlets were taken off from a small box, that allowed you fill either
tank, or with care, both tanks at once.
As mentioned above, you have to make sure that there are no kinks in any hoses, and that the filler hoses go as direct as possible to the tanks. Breather hoses at least 1/2" seem to work the best too, as per Toyota HDJ78/79's. Some of the later model tanks appear to have an air chamber designed into the upper surface of the
tank, which I imagine, may reduce the effect of
fuel splurge?
816605
