Adjustable towball hitch (ATH) Vs WDH
Submitted: Friday, May 30, 2014 at 10:45
ThreadID: 108019 Views:2695 Replies:2 FollowUps:7
G'day,
Not much in the search topics on this.
Just wondering if anyone has gone with a ATH instead of a WDH & if they work OK?
There is certainly a price issue between the two & it looks like a much quicker set up time, they look like they should work OK?
Any feed back is appreciated.
Tony
"For the Rover's life has pleasures, that the townsfolk will never know" - sort of from Banjo Paterson
Reply By: Member - Rod N (QLD) - Friday, May 30, 2014 at 11:08
More info on the ATH? How does it work, link to a description?
AnswerID: 533449
Follow Up By: Member - Sanantone - Friday, May 30, 2014 at 11:46
They can drop or raise the trailer or caravan.
Adjustable Towball Hitch
Tony
FollowupID: 816809
Follow Up By: Member - Rod N (QLD) - Friday, May 30, 2014 at 12:00
Thanks Tony. It appears to be a hitch that can be height adjusted to enable the towed vehicle to be level.
It is nothing like a WDH and won't do the same job. The WDH transfers weight back to the front wheels.
This subject can go on and on. There have been pages and pages of comments on this subject on the Caravaners Forum.
FollowupID: 816812
Follow Up By: Member - PJR (NSW) - Friday, May 30, 2014 at 12:20
I agree with Rod. They can't be compared as they do different jobs.
FollowupID: 816813
Follow Up By: Member - Keith C (NSW) - Friday, May 30, 2014 at 12:26
G/day Rod, I use one of these on my set up, I think you still need a wdh to take the weight off the tow ball and balance the rig, the tow ball should be the same height as the van when the van is level but unhitched, when you hitch, up and remove the dolly wheel the hitch will take the weight, ie.,ball weight, thats when the wdh is used to level up and transfer some weight onto front wheels. Keith
FollowupID: 816815
Follow Up By: Member - Sanantone - Friday, May 30, 2014 at 12:39
Bugger, I thought I had saved myself a few bucks, now it looks like I might have to add a few more:)
Tony
FollowupID: 816818
Follow Up By: 671 - Friday, May 30, 2014 at 13:49
Tony
The others are right. The difference with a WDH is it is a lever, not a spring, spacer or anything else. When you lift the bars up and hook them onto your draw bar, it is like lifting the handles on a wheel barrow. You take weight off the rear suspension and transfer it to the front.
FollowupID: 816822
Follow Up By: Ross M - Friday, May 30, 2014 at 20:01
The WDH has to be a spring other wise the whole thing would be rigid.
The WDH does transfer weight but it also INCREASES the load on the ball not lessens it.
It lessens the weight effect on the rear suspension though.
If you put your hand between the coupling and the ball and then get someone to tension the WDH bars up. They will have to stop because of the noise.
FollowupID: 816846
Reply By: WBS - Friday, May 30, 2014 at 16:49
The hitch picture has nothing to do with what a WDH is all about. In fact, most WDH have an adjustable towball to suit different heights of vehicle as well as an adjustment for the angle of the towball on the hitch. That might sound fancy but in fact it is just part of a WDH set up.
WBS
AnswerID: 533469
