SPOT CONNECT
Submitted: Monday, Jun 02, 2014 at 13:04
Member - Rob G1
Just wondering if anyone has a Spot Connect, whether it is working
well? We have an android phone and hoped to pair it with
the Spot Connect. We have paired it but can't get it to respond to
the Spot Connect without being close to the internet connection. We are doing it all via Bluetooth which is supposed to work. Any ideas or hints or have we made a bad purchase?
Rob
Reply By: The Landy - Monday, Jun 02, 2014 at 14:02
Hi Rob
I don’t necessarily use
mine as a safety device, but pair it to ExplorOz for EO Track me. This way family and friends can view were we are. I do use the pre-populated message feature to send “I’m okay” messages, and I guess it is a back-up to our 406 PLB device.
Depends on what you want to use it for, but overall I would rate 8 out of 10 for the way I use it.
Baz – The Landy
533600
Reply By: aboutfivebucks (Pilbara) - Monday, Jun 02, 2014 at 17:14
We pair our Connect with plenty of devices including Android phones and tablets.
Make sure you've performed the firmware update when you unbos
the spot - to do this you must plug
the spot connect into a computer. Its easy - google spot connect firmware update.
The other trick is to reduce the amount of blue tooth devices active. eg the phone might be trying to pair to the car stereo when you need it to pair to
the spot.
The start sequence for the android devices is:
1. Make sure Spot app is not active on the phone
2. Turn the phones blue tooth on
3. Start
the Spot app
4. Start
the Spot Connect (Hold button in until blue light comes on)
If this doesn't work . Turn off spot, turn off phone blue tooth, deactivate spot app and start from step 1 again.
This sequence works
well for us. And we are usually out of phone range when we start it up.
Two other tips
1 connect at home or in phone range regularly to synchronize settings.
2 use only the high powered lithium batteries. Alkaline batteries wont last a day.
Good Luck
533611
Reply By: Member - Ian F (WA) - Monday, Jun 02, 2014 at 18:17
Hi Rob, I use
mine with an iPhone and iPad but will only work separately.
Ian
533614
