Plasmatronics still in business?
Submitted: Tuesday, Jun 03, 2014 at 06:49
ThreadID: 108078 Views:2097 Replies:1 FollowUps:0
I've been using a Plasmatronics PL20 regulator in my camper for the last 7 years and it
has been giving me reliable service.
Lately it has been reading the voltage out by about 2V. Would this damage my 220Ah AGMs?
I spoke another guy at a campground on the Stuart who said Plasmatronics were going out of business and laying off staff. Looks like I need to upgrade to a MPPT.
LL.
Reply By: Ozhumvee - Tuesday, Jun 03, 2014 at 07:34
I wouldn't be so quick to suspect the PL20 is faulty, the voltage difference could be a crook connection like a fuse cct breaker, wire or just a plain connection fault.
I had the same with a system which includes a PL40 and there were two connection points that individually dropped he voltage by a minute amount but both added up to a couple of volts.
Might be time to go right through all connections including spade fuses (a known fault point) and replace/clean/reterminate everything especially after 7 years. Don't forget the ground/earth connections.
MPPT are not the best for many RV setups either unless you are running higher voltage panels etc.
AnswerID: 533635
