Chipping a pajero
Submitted: Wednesday, Jun 25, 2014 at 22:15
ThreadID: 108493 Views:2505 Replies:5 FollowUps:4
Hi everyone ! Me again.....
Hubby has asked is it worth chipping a 2005 Pajero diesel ?
And if so do any of you knowledgable car/ caravan enthusiasts know which chip ??
Thanx petra
Reply By: Idler Chris - Wednesday, Jun 25, 2014 at 22:35
Petra to get meaningful replies it would helpful if you stated what it is that you want to achieve. What is your expectation?
AnswerID: 535017
Follow Up By: John and Regina M - Wednesday, Jun 25, 2014 at 22:46
And post yr question in the Victorian Pajero forum.
FollowupID: 818840
Follow Up By: Emerging I.T. - Thursday, Jun 26, 2014 at 12:00
Agreed on both counts. Chipping has it's benefits, sometimes the better answer is buy a different vehicle, that's a comparison that needs to be made at the time.
FollowupID: 818851
Reply By: Jackolux - Thursday, Jun 26, 2014 at 12:12
Is the Pajero going ok and doing the job now , leave it alone ,
AnswerID: 535026
Reply By: 410 - Thursday, Jun 26, 2014 at 12:27
Hi Petra,
My mate who is a mechanic had a Pajero 2004 model and put a chip in it, but soon took it out as he didn't like the way it affected the car. I would not do it myself, you do not mention how many kms your car has done, if it has done a couple hundred thousand doing the injectors may help. My mate did say they are a great motor and have seen plenty with thousands of kms and not touched the motor.
Rich
AnswerID: 535027
Reply By: wholehog - Thursday, Jun 26, 2014 at 18:43
Your would probably get a better and cheaper result cleaning up the EGR system.
AnswerID: 535049
Reply By: patsproule - Thursday, Jun 26, 2014 at 20:49
I have an 05 diesel Pajero. Short answer is yes, it is worth it. Blocking EGR is also a good idea but it will not improve performance anywhere near that of the chip. And I have done both.
Longer answer - The pre-common rail pajeros (which yours is) have a reasonably unsophisticated injection system and ECU. Thus the chip options are equally limited and basic. I have a DP chip in mine and when set correctly the performance difference is huge. The negatives are that to get the best performance gain it over-fuels a bit at idle and it is therefore smelly and rough at idle. But it brings boost in much earlier and will hold a full gear higher than before, powering over most hills in top gear. I unplugged my chip a while ago as I was annoyed at the idle but I soon put it back in as it was a slug without it.
You wont find many to choose from on the old rotary injection pump but they all do much the same thing - extend the pulse width sent to the injector pump.
Good luck - Pat
AnswerID: 535054
Follow Up By: patsproule - Thursday, Jun 26, 2014 at 20:51
EDIT - I have a Tunit II - imported it from the UK at half the local $.
FollowupID: 818893
Follow Up By: olcoolone - Thursday, Jun 26, 2014 at 21:22
So many think by chipping a diesel you will turn it in to a race car and you will cause expensive damage.
Long way from the truth, what I have found is it makes the driving experience so much better and if any thing it turns one in to a lazier driver by enjoying the extra torque...... Drivability increasers significantly.
FollowupID: 818896
