Saturday, Jul 12, 2014 at 22:20
"671 - what car? "
2003 Hilux 4x4. Goodyear Wrangler TG 205R16 LT 112 load rating.
Two other tyres are listed in the book in addition to the 205 street tyre. One is a 255/70x15 LT 112 load rating. The pressures are 28 psi front at all times. The rear is 28 to 34 depending on load. That tyre would probably be standard on the SR5 version. My car is the basic no frills variety.
The other is a 195R14C presumably for the 2wd version. Its pressures are 32 front at all times and 32 to 65 rear depending on load.
I was still not convinced that these pressures were correct even after talking to Goodyear but I thought both they and Toyota knew more about the car and its standard size tyres than I did so I did what they said. The result has been a 100% success.
Goodyear also told me NOT to reduce the pressures on unsealed roads so I don't. The only exception was on a climb to the top of Big Red and back down again. I reduced them to 14 front and 18 rear at the bottom of the
hill then re-inflated them to the same previous hot pressures when I went down again. The car went straight up in third low at the first attempt.
The car has been to the top of Blue Rag in the VHC back in 2008 when the track was still very rough. It has been graded recently. Last year it went through Dalhousie, Mt Dare, the Sandy Blight and the Gunbarrel on the same factory pressures that I left home with in
Sydney. There have been plenty of mountain and desert trips between those two trips. All have been on the same pressures that I left home with.
Living in
Sydney means the tyres see plenty of freeway use. Even at the recommended 25 in the front, they don't overheat or wear the outside edges as they would if they were under-inflated.
The difference with these tyres is they are commercial sizes. The TG only comes in a 14 inch, a 205 x16 and two 7.50 x16 in different load ratings. I have lived in the bush for many years and worked in the motor industry for part of it. The majority of locally owned 4x4s used 7.50 x16 tyres and the owners did not change pressures from one road surface to another. It would drive you crazy in some areas if you had to do that. I can only assume that these tyres have been designed to work in those conditions at the same low pressures all the time. Maybe that is why Toyota still fits a 7.50 x16 to the basic Cruiser ute and the Troop Carrier. The whole Outback seems to run on that size in both steel belted radial and very heavy cross ply for cross country work.
The magazines don't cover the 205 and the 7.50 x 16 so going everywhere at the same pressures never gets mentioned. Companies like Cooper and Micky T do recommend changing pressures but they don't make those two commercial sizes.
A lot of tyres look the same but are they? You can't tell by looking. This is why I will always recommend talking to the tyre manufacturer, not the tyre service, when you buy new tyres. The dealer who fitted my tyres said the pressure should be 40 psi. That would have shaken the body off the chassis.
There is always a lot more to the design of both suspensions and tyres than meets the eye. The standard tyre and the recommended pressures is part of the design. It is not an after thought intended to keep the car off the ground until the owner buys something better.
819992
