How do you access the settings on Eotrackme on a Samsung Galaxy S5
Submitted: Thursday, Jul 10, 2014 at 22:40
Member - Chooky and Wobble
I have recently changed to a galaxy S5 Samsung phone. I downloaded the EOTrackme app and I can't find the way to bring up the settings to input my Member number. There doesn't appear to be any button or location to bring up the menu.
The app starts and all appears to work except of course it is asking to put in the member number in settings.
Reply By: ExplorOz - David & Michelle - Thursday, Jul 10, 2014 at 23:04
The S5 has hidden the menu key. You are not the first person to ask this question. I found a post on the net that tells you where it is but basically press and hold the lower left hand side app key for a few secs and the menu will appear.
The post is here:
http://www.androidcentral.com/samsung-galaxy-s5-menu-button-hidden
David
535845
Follow Up By: Member - Chooky and Wobble - Thursday, Jul 10, 2014 at 23:22
Thanks David that worked. Now it comes up with my member number invalid. Does it need to be reset for the new phone?
819801
Follow Up By: ExplorOz - David & Michelle - Friday, Jul 11, 2014 at 11:56
Ah no it should just work. If it say invalid just check you have the M at the front and no spaces at the beginning or end.
David
819826
Follow Up By: Member - Chooky and Wobble - Friday, Jul 11, 2014 at 14:53
David all ok now, couldn't edit the device on the android, had to go back to the laptop to rename it etc.
By the way for the member number, I put the M in and noticed the software was adding another M, so left the M out and it logged on.
You need to travel more and work less
Colin
819835
Follow Up By: ExplorOz - David & Michelle - Friday, Jul 11, 2014 at 16:26
YES I DO.
David
819845
Follow Up By: ExplorOz - David & Michelle - Friday, Jul 11, 2014 at 16:27
Hey why could you not edit on the Android?
819846
Follow Up By: Member - Chooky and Wobble - Friday, Jul 11, 2014 at 16:55
David,
When you bring up the page where the edit is available on the Samsung android, it doesn't form the page correctly and the edit link is scrambled and won't accept clicking on. The only command that will accept clicking on is "get embedded code". I just tried it again and it worked, so not sure what happened the first few times I tried.
I'm not sure if it was related to the option of clicking on "mobile option" which I did the first time. This time I left it as the full display.
Col
819847
