Engel fridge power
Submitted: Tuesday, Jul 29, 2014 at 22:17
ThreadID: 108941 Views:2625 Replies:2 FollowUps:2
Do all engel fridges work on 12 & 24 volts by just pluging into power socket car 12v or truck 24v?
Reply By: Member - Stephen L (Clare SA) - Tuesday, Jul 29, 2014 at 22:31
Hi Duck
The short answer is yes.
It is advisable to unscrew the 12v plug on the end and use one of their othere fittings that are available.
AnswerID: 536825
Follow Up By: Ross M - Wednesday, Jul 30, 2014 at 08:56
What about the Engels which were never marketed as being 12v &24v and only ever mentioned as 12v. ie pre fan models.
Are they also 24v compatible?
I have one which is 20years old and have never noticed any info relating to 24v.
FollowupID: 821053
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Jul 30, 2014 at 09:06
Hi Ross
Your fridge will also be fine on 24 volts. All Engel fridges are all 12/24/240 volt compatible.
FollowupID: 821055
Reply By: John and Regina M - Wednesday, Jul 30, 2014 at 13:01
It would be wise to, unless it is specified as also 24v, to just use it on 12v otherwise you may be in for a repair.
Have you tried the manufacturers? They may have more info available than this forum.
AnswerID: 536849
