Eva kool problem
Submitted: Monday, Mar 01, 2004 at 10:25
Ferret
Greetings all, I went to use my ED40 yesterday which is little more than a year old and the thing no go! The comp. cuts in for about 5 seconds and then cuts out, but the fan is still running. Any ideas as to the problem? Please, no should've bought a Waeco/engel or whatever...
Thanks Scott
Reply By: flappan - Monday, Mar 01, 2004 at 10:26
Whats it plugged into . . .
Low Voltage cutout ?
48726
Follow Up By: Ferret - Monday, Mar 01, 2004 at 12:05
Plugged into car both running and just off Batt.
Yeah thought about that but the fan is still running, and know fault LED's up?
310532
Reply By: Member - Wim (Bris) - Monday, Mar 01, 2004 at 11:18
Ferret.
Symptoms would appear to eliminate most of the electrics. I think from memory the fan is wired from the compressor.
If you have the 240vac/24vdc adaptor try that. If problem persists, check wiring in comp terminal box.
RegardsIs it tinea or has it just been too long since the last trip?
48729
Follow Up By: Ferret - Monday, Mar 01, 2004 at 12:07
Haven't tried the 240v thingy yet but will when I get home tonight.
Cheers Scott
310533
Follow Up By: flappan - Monday, Mar 01, 2004 at 12:24
I thought they were seperate . . . I'm sure my EvaKool is ???
Mines about 10yo though . . . not sure of current specs.
310535
Reply By: Martyn (WA) - Monday, Mar 01, 2004 at 11:53
Ferret,
Shoud've bought an Engel................ LOLKeep the shiny side up
48733
Thanks Marty!!!
310534
Follow Up By: Martyn (WA) - Monday, Mar 01, 2004 at 13:03
Hey, has the noise gone away or has it returned? Did you find out what it was?
310539
Follow Up By: Ferret - Monday, Mar 01, 2004 at 13:11
All gone!!???
310541
Follow Up By: Member - Eskimo - Monday, Mar 01, 2004 at 17:21
does it run on 240Wow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
310564
Reply By: Wayne (NSW) - Monday, Mar 01, 2004 at 14:18
Ferret,
Could be the compressure or it might be out of gas.
Should have bought a...........
WayneAlways Out'N About
48752
if it was out of gas it would run for a lot longer than 10 seconds.
There's lots of reasons why it is only running for 10 secs but out of gas aint one.
310563
Reply By: Member - Oskar(Bris) - Monday, Mar 01, 2004 at 15:54
Ferret
My RF47 did something similar (run for 10 seconds or so and then turn off) and I found, when I had the electrical system checked, that I had a battery/alternator problem.
I fixed that up and now I runs like it should.
If it runs on the 240V power pack or even on a reasonable battery charger it should run on you vehicles system.
Maybe check your battery terminals and all fittings and connections.
And BTW you should have bought an Evakool! LOL
oskarThe real oskar
48762
Reply By: Viola - Monday, Mar 01, 2004 at 21:33
Darling that is because the wiring is to light dear or you are using a smokey smelly stinky plug dear. Darling the good man at the auto electrician fixed me right up with proper plugs and heavy wiring. Darling hopefully he can fix up hubby to dear or else I may need the handsome gorgeous auto electrician man to wire me right up.
48796
Follow Up By: Ferret - Tuesday, Mar 02, 2004 at 09:47
Not sure what to make of this! I think you might be right though. Got home last night and plugged it into the 240v thingy and no probs. Must have been borderline before.
Anyone know what voltage they cut out at? 10.6Vs?
Thanks Scott
310656
Follow Up By: flappan - Tuesday, Mar 02, 2004 at 09:58
I thought it was 10.4v , but as I said before mines 10 yo, so not sure of current specs.
10.4/10.6v Probably 2 fifths of bugger all anyway . . . I think theres a bigger underlying problem.
310657
Reply By: Boeing - Tuesday, Mar 02, 2004 at 20:00
Ferret, Whilst it sounds as if your battery is a bit dodgy, it may not be. If you have a multimetre check what the voltage is when the fridge attempts to start by pulling out the plug just enough to touch the multimetre ends with. + to + and - to - of course! This is the only way that you can see what the start attempt is drawing. If your battery is OK and so are the leads/plugs, it may be the electronic controller as I had the same thing happen to a Danfoss equiped fridge. Replaced the electronic box and it worked fine. What is the warranty on the Evakool's?.
Mark
48918
Reply By: scott111 - Friday, Mar 05, 2004 at 17:34
if it works on 240v then its got to be your 12v supply isnt supplying enought power
49294
