Making a sand anchor?
Submitted: Tuesday, May 07, 2002 at 00:00
ThreadID: 1093 Views:2715 Replies:2 FollowUps:0
Using the spare wheel is good if the groung is sanding but what about if the groung is a bit hard.
Can any one suggest an other technique to anchor in the ground?
I do not like single pickets being driven in the ground because this is hard work.
Is there a sand anchor whioch will work for harder surfaces?
Guy
Reply By: Sam - Tuesday, May 07, 2002 at 00:00
Guy,
there is an item called the portable rescue tree. check out
http://www.alphalink.com.au/~wdt/Rescue.html cheers Sam.
AnswerID: 3394
Reply By: Sam - Wednesday, May 15, 2002 at 00:00
Guy, in addition to what I said above, check out http://www.anchorright.com.au/ cheers, Sam.
AnswerID: 3567
