Some info from a panel beater needed
Submitted: Tuesday, Mar 02, 2004 at 17:57
ThreadID: 10944 Views:1757 Replies:0 FollowUps:0
I have just repaired a small amount of rust in a double panel. I've bogged up the small hole and now intend to paint and finish off. Can I rust proof behind the panel with an oil based product??? Spray will go on the panel with the bog on (at the rear) so will it cause the bog to let go, can it creep into the joint and make it fail????
