80 Series Window Regulator Motor Advice
Submitted: Friday, Sep 26, 2014 at 17:10
dbmaxpayne
Hey,
how are yas goin?
Unfortunately my front LH side's power window stopped working.
I haven't pulled it apart yet, but I already saw some
forum topics about failing motors and stuff.
I thought it might be better to just get a new one and so I did some research.
Genuine motors are around $260, but then I found those:
TOYOTA LANDCRUISER 80 SERIES POWER WINDOW REGULATOR LH NEW
Has anyone tried them yet?
Cheers, Mark
Reply By: get outmore - Friday, Sep 26, 2014 at 18:13
while it could be the motor first thing id check is to see if its actually getting power
539563
Reply By: Ross M - Friday, Sep 26, 2014 at 19:51
If it is the motor and not just the switched supply of 12v. Many, many motors are available from doors at wreckers. Most look and are the same. maybe a few brands.
Any motor of same same out of a smashed door will be cheap and effective.
If from the rear windows of a vehicle they will be almost brand new, although might require a lube with oil on the bushes to ensure top performance.
Never go and buy new or after market, when genuine nearly new is perfect.
539566
Reply By: mudbro2 - Friday, Sep 26, 2014 at 21:33
I agree with get outmore, check for power. I had a 62 series which had same problem so I pulled the switches out and found the terminals were quite dirty. Cleaned the contact points on the switches and all fixed so worth a try before you spend your money.
539569
Reply By: dbmaxpayne - Saturday, Sep 27, 2014 at 09:59
Thanks guys, forgot to mention, that I did check for power. Power is there, but no movement at all. The Motor is not even trying.
I will check the wreckers here in
Cairns, thanks^^
539581
Reply By: The Ferret - Saturday, Sep 27, 2014 at 16:59
My RH front power window failed and I replaced it with one from Westside over a year ago. It is still going good and I can recommend it.
Regards Dave
539592
Reply By: dbmaxpayne - Thursday, Oct 09, 2014 at 12:50
Hey guys,
just got my replacement regulator, but I'm curious how to wind the window down manually to get it out?
Since the window is stuck all the way up, I probably can't get the regulator out the service hole :-/
Cheers, Mark
540128
