Camec water fillers
Submitted: Saturday, Oct 04, 2014 at 14:38
*Rusty*
Calling all Adventure offroad camper trailer owners (or anyone who knows about
water fillers). I need your help. Our Adventure lost the inside of the
water filler (not just the cap) off the camper on heavy corrigations and Camec dont make the screw type
water filler anymore so we replaced it with the new version which has a hinged door instead of the screw cap. Has anyone had to replace their
water filler complete unit (not just the screw cap). The new version is flawed and allows
water to return up the breather hose and fill the cavity underneath as their "breather" is just a hole in the breather pipe which as
well as letting air in to pressurize the
tank, it also lets
water out when you fill it up funny enough. The old version sucked air in through the screw cap and didn't have this little hole in the breather pipe. If you seal the hole on the new one, the door certainly seals tight and sucked the
tank in. Camec have been less than helpful to say the least. We have tried fitting a one way valve that camec supplied additionally but they either arent sensitive enough to open when needed or lets
water escape through it still. Has anyone solved this problem or do you know a different brand with the same mounting holes and has the breather tube hole protected from dust (as some brands breather hole is exposed to dust if you look carefully).
Reply By: Peter T9 - Saturday, Oct 04, 2014 at 16:56
Isn't there a nipple on the filler pipe you connect the breather hose to?
539918
Follow Up By: *Rusty* - Saturday, Oct 04, 2014 at 18:06
Its not a nipple just a 10mm pipe outlet where you hose clamp the hose onto.
825563
