Dynamic black steel after market rims
Submitted: Wednesday, Oct 15, 2014 at 15:13
ThreadID: 109826 Views:3914 Replies:6 FollowUps:2
Hi all has any one heard or had any trouble with these rims cracking.
I am thinking of buying a set for my 200 series l/cr for off road tyres.
Reply By: Travelling - Wednesday, Oct 15, 2014 at 16:02
all rims today have to be certified for weight and stamped accordingly.
buy the correct rims and you are highly unlikely to have a problem
AnswerID: 540399
Reply By: Member - Phil G (SA) - Wednesday, Oct 15, 2014 at 17:48
I have them on my TVan so I can put them on the 200series if necessary as a spare. They look strong enough - rating is 1400kg and I haven't heard of any probs with the dynamic branded wheels.
But the 200series is 60mm pos offset and these rims are only 30mm offset. Means you will widen the track by 60mm which is twice the legal limit. If you're fitting 285 tyres they will sit at the edge of the mudguards. You'll need to use the standard steel wheelnuts.
There are no aftermarket steel wheels available in 60mm offset - because they wouldn't be strong enough. The factory steel wheels are strong and are 60mm offset and would be my preference in steel.
AnswerID: 540405
Reply By: olcoolone - Wednesday, Oct 15, 2014 at 19:55
Genuine Toyota 17x8 are only around $120 each for the 200 series.
AnswerID: 540415
Reply By: The Bantam - Wednesday, Oct 15, 2014 at 23:23
the dynamic steel wheels atre one of the strongest an most reputable wheels of their type available in aus.
lots of guys run em on their comp trucks.
I have a set of 6 for one of my hiluxes...a couple of years ago I got clobered by a chick in a Subaru tyring to over take me across double whites while I was dooing a u turn.
The front drivers wheel took the direct hit hard enough to snap a tie rod......the wheel ended up well bent...but no sign of cracks or structrual failures.
which is more than you can say for many of the cheap steel wheels....I know a bloke who went thru 8 wheels to get 4 straight ones......new out of the box.
the ther good thing about the dynamic wheels....they can be had off the shelf in white black or silver.
AnswerID: 540427
Reply By: 489 - Thursday, Oct 16, 2014 at 09:56
I have purchased 5 of these rims 3years ago and done many k's through the outback on dirt, stone and sand with no signs of fatigue. Just needed to re-balance after each trip to keep things in order as one would expect. They balanced up ok with no further problems.
location - Warragul -Victoria
AnswerID: 540437
Reply By: Member - reggy 2 (VIC) - Thursday, Oct 16, 2014 at 10:40
Thanks folk for your in put, I will look at the toyota check out there prices.
The after market dynamics I was looking at were 60 mm offset which is the 200 series,Thanks again cheers
AnswerID: 540439
Follow Up By: Member - Phil G (SA) - Friday, Oct 17, 2014 at 18:55
The 60mm offset listed by Dynamic are actually the genuine Toyota steel rim.
The IFS listing above it is 30P offset and look like the normal sunraysia (that's the silver version on my Tvan).
http://www.dynamictyres.com.au/Portals/0/Dynamic%20Wheels%20Tech%20Sheet.pdf
FollowupID: 826364
Follow Up By: Member - reggy 2 (VIC) - Saturday, Oct 18, 2014 at 20:04
H i Phil
The rim that i looked at was not like any of those at the site you put up or your tvan.
The toyota IFS rim at the bottom of the site is the same as my original 200 series which I have ordered from toyota cheaper than the after market it was a big surprise .
FollowupID: 826399
