Thread size
Submitted: Monday, Nov 03, 2014 at 22:28
ThreadID: 110029 Views:4781 Replies:3 FollowUps:3
Does any one know what type of thread is on a Staun Tyre deflator. (The thread that screws on to the tube) I need to repair the thread on one of my deflators but I cant seem to find a tap to suit it. Any suggestions?
Reply By: Hoyks - Monday, Nov 03, 2014 at 22:49
"External thread
Metric: 7.7 mm OD, thread root diameter is 6.9 mm × 0.794 mm pitch.
Imperial: 0.305 in OD, thread root diameter 0.271 in × 32 tpi (threads per inch)"
http://en.wikipedia.org/wiki/Schrader_valve
A bit more digging indicates that it is a 0.307 x 32 UNS (Unified National Special ) indicating it is an odd size, but taps are available.
Might be cheaper to buy a new set of deflators though...
http://www.engineering-supplies.com/product/12137/a-0-307x32-uns-hss-ground-thread-tap-schrader-valve-tap-/
AnswerID: 541275
Follow Up By: Cruznoz - Tuesday, Nov 04, 2014 at 08:42
Thanks Hoyks.
You may be right. A UNS tap is a bit pricey.
I thought I might be able to dig a tap up at work if I knew what I was looking for. But I doubt I will find a UNS tap.
Thanks for your help
FollowupID: 827356
Reply By: Member - Ed C (QLD) - Tuesday, Nov 04, 2014 at 13:18
Rema Tip Top have in their cattle-dog a 4-way valve repair tool EX-1525
(mainly for tractor tyres) which has 2 internal thread cutters, VG8, & VG10..
I'm not 100% sure (as I don't have one to check), but I think the VG8 size is the one you're looking for...
Have a look here >> Rema Tip Top valves & valve accessories
Scroll down to the "Valve repair tools" and check out Ref. No. 102111
Here's a closer look >> Valve tool EM EX-1525
Any tyre place which regularly handles tractor tyres would probably have a few lying around...
Confucius say.....
AnswerID: 541291
Follow Up By: Cruznoz - Wednesday, Nov 05, 2014 at 08:38
Good idea. I might try my local tyre shop.
FollowupID: 827411
Reply By: MUZBRY- Life member(Vic) - Wednesday, Nov 05, 2014 at 07:30
Gday
I have one in my ash tray ....I am in Melbourne if you need to use it ...
AnswerID: 541316
Follow Up By: Cruznoz - Wednesday, Nov 05, 2014 at 08:39
Want to do a quick trip with it over the Nullabour to Albany?
FollowupID: 827412
