Hard Shell Roof Top Tent on Ute
Submitted: Tuesday, Nov 04, 2014 at 16:13
Phil P
Hi all,
I'm back considering Roof Top tents again (I still like my centre pole touring tent).
I have had a look at the James Baroud Tents and can't really fault them except for the width. They would hang a fair way over my Hilux canopy. The tent is 1450mm wide and my roof rack is only 1236mm wide.
The Maggiolina's have an excellent reputation (other than the price). They have models that are 1300mm wide.
The question I have is that my Hilux has a steel canopy with Rhino Tracks and a Pioneer Roof Platform. The Roof Platform is 1236mm (W) * 1528mm (L). The Rhino Feet that are holding the platform are only about 1100mm apart.
This would mean that more than half the length of the roof top tent would not be supported. I estimate that 1M of the Roof Top Tent will be hanging over the platform. The last section of the platform that is supported by the Rhino feet is around 500mm from the front edge of the Rhino Platform.
My option is to have another Rhino Track installed on the Cabin part of the ute, this way the Roof top tent is fully supported. I have read that it's not advisable to fasten long loads between the Canopy section and the Cabin.
Does anyone have any experience with work arounds for securing long loads between the Cabin of a Ute and the Canopy?
This would be quite an expensive project and as I'm planning on keeping the vehicle for a long time it will be travelling the usual corrugated tracks and the last thing I want is issues.
Thanks in advance
Phil P
Reply By: AlbyNSW - Tuesday, Nov 04, 2014 at 17:28
You definitely will have problems if you connect anything rigid between racks on your tub and your cabin.
The amount of flex and movement between the two is substantial so you will need to decide on mounting off one or the other but not both.
541297
Reply By: Grizzle - Wednesday, Nov 05, 2014 at 13:36
A friend of
mine did it with a Hilux. Had the third bar on the cab and packed it up with high density foam to the underside of the capsule. (Maggiolina style Capsule tent). Worked really
Hope this picture gives you the idea
Hilux Rooftop Tent
541329
Follow Up By: Member - Scott M (NSW) - Wednesday, Nov 05, 2014 at 16:15
Grizzle, yeah I've been thinking of a response to this thread a while - been scratching my head - the only answer I could come up with is to put a bar on the cab but not fasten the RTT down - a good bit of supporting rubber would allow flex while travelling, but be enough to support the shell when being used.
Seems like the idea works...
827435
Reply By: Phil P - Thursday, Nov 06, 2014 at 07:32
Thanks for your suggestions, I think the safest option is to buy a canvas type Roof Top tent. That way it will easily fit on the canopy bars. Just more work setting up & packing up.
541354
