Faulty Fuel gauge
Submitted: Saturday, Nov 15, 2014 at 08:15
ThreadID: 110143 Views:3056 Replies:3 FollowUps:4
Hi All
I have a 1999 75 series diesel troop carrier .
The back fuel tank gauge (The one on top of the dash ) has stopped working suddenly .
It reads empty all the time.
Any help would be appreciated.
Reply By: Member - Colin E - Saturday, Nov 15, 2014 at 08:19
Check all the wiring first
My main tank gauge didnt work for over a year and ot was only a broken wire
AnswerID: 541687
Follow Up By: Member - mark D18 - Saturday, Nov 15, 2014 at 08:26
Thanks Colin
Pretty sure I have checked all the wiring ( but I will double check anyway )
FollowupID: 827864
Reply By: Slow one - Saturday, Nov 15, 2014 at 08:55
Mark,
Just to rule one thing out. If the fuse is blown other lights or gauges on the dash won't work.
If you break the wire to the fuel tank the gauge should move to over full with the ignition on. So that will prove the gauge is ok.
Their is a plug on the back of the gauge which is pretty easy to access so you could have a look at that.
Other things are, the wire to the fuel tank sender is shorted to earth which will show an empty tank or the sender itself is stuck down or the float has fallen off. The sender rheostat could also be faulty itself could. If the earth is broken off the tank sender the gauge should be reading over full.
If it is the sender it is not to hard to drop the back tank.
Hope this is of some help
AnswerID: 541689
Follow Up By: Member - mark D18 - Saturday, Nov 15, 2014 at 09:05
Thanks Slow one
I will go though your suggestions
FollowupID: 827865
Reply By: Bob Y. - Qld - Saturday, Nov 15, 2014 at 10:22
Mark,
We had the same problem on a 75 series, on rear tank, and one of the internal baffles had broken away and kept the float at empty.
Pulled the sender out and that rectified the problem until the tank was near empty again, and same problem reoccurred.
AnswerID: 541690
Follow Up By: Stu & "Bob" - Saturday, Nov 15, 2014 at 11:49
I have the same problem on a 75 series.....
FollowupID: 827869
Follow Up By: Member - mark D18 - Saturday, Nov 15, 2014 at 11:54
Thanks Guys
I try that as well
FollowupID: 827870
