HJ60 Landcruiser Replacement Front Seats
Submitted: Saturday, Dec 06, 2014 at 23:23
morto1701@gmail.com
Hi Guys
I am after some opinions on the best option for the front seats. I know Recaro seats would be the best (I think) but I a hoping for a cheaper option as I need to replace the front seats in the HJ60 I just purchased.
I would appreciate any thoughts you may wish to pass on.
Tension Wrench
Reply By: morto1701@gmail.com - Saturday, Dec 06, 2014 at 23:24
Apologies, this is a 1985 Sahara.
542649
Reply By: 671 - Saturday, Dec 06, 2014 at 23:48
Unless someone has a better idea, the best thing to do is start with a serve yourself wrecking yard and a tape measure.
I did this many years ago with a Mitsubishi L200 ute that I was rebuilding with a permanent
camping body and a different engine and transmission. I chose a couple of seats from a VN Commodore. They were extremely easy to fit, they passed engineering without any problems and gave us a very comfortable ride for many years everywhere from
Cape York to the bottom of Tasmania.
Those seats are far too old now but I doubt if I would have any trouble doing the same thing today with later models.
542650
Follow Up By: morto1701@gmail.com - Sunday, Dec 07, 2014 at 12:38
Thanks for that
829130
Follow Up By: Ron N - Sunday, Dec 07, 2014 at 14:49
I'll second 671's suggestion. It's surprising what fits what, and what you can find in wreckers yards. Go for the luxury Toyota vehicles and you'll find superior seats - and you may find that another model of Toyota has seats that will fit without major hacks and chops.
829140
Reply By: Member - bbuzz (NSW) - Sunday, Dec 07, 2014 at 07:57
Hi morto,
I did this to my HJ60 (1984).
A trip to the wreckers yielded a pair of Ford Fairmont seats, with lumbar adjustment and a few other nice things.
The fitting was easy, the fronts bolted into the existing channel and the towers for the back were relocated with reinforcing plates under the bolts. The old holes from the towers in the floor were filled up with solder.
In NSW I had to get a Blue Slip and change the rego from a 6 seater to a 5 seater. No problems with that either.
Very comfortable for touring.
A slight problem if you are tall in the upper body as they do sit a little higher, but I liked the increase in height from a driving point. That could be solved with a cutout in the channel.
bill
542656
Follow Up By: morto1701@gmail.com - Sunday, Dec 07, 2014 at 12:39
Thanks Bill I will check it out
829131
Reply By: Member - David Will (VIC) - Sunday, Dec 07, 2014 at 11:26
Check out the classified section.
542668
Follow Up By: Allan B (Member, SunCoast) - Sunday, Dec 07, 2014 at 12:41
Hi Tension, If you are having trouble locating the classified listing
click here.
829132
Reply By: The Bantam - Sunday, Dec 07, 2014 at 13:57
There are any number of expensive after market seats arround recaro and stratos among them.
But often people are disapointed at the comfort and practicality delivererd by some of these
aftermarket seats, particularly considering the price.
Some of these afrermarket seats also have complicated and bulky mounting systems that might not suit a particular vehicle.
In this day and age there are some teriffic seats comming factory fitted to vehicles......these of course can be had from the wreckers.....but often you either have to be quick or wait for the right seats to come along.
You would be wise to look for a
seat that comes from a vehicle with a similar sitting attitude.
Because a
well designed
seat will differ in its upper leg support and lumbar shape between a seating position with flat extended legs ( like found in most sports cars)and an upright seating position( as found in 4wds).
Hell if you stick with toyota ya might even find something that is close to bolting straight up.
542674
Follow Up By: morto1701@gmail.com - Sunday, Dec 07, 2014 at 14:00
Thanks "The Bantam"
829135
Reply By: Member - Brian - Sunday, Dec 07, 2014 at 22:01
Hi there mate , my HJ61 which is very similar to yours has Nissan seats ( dont tell anyone !!) And they are quite comfortable
542694
Follow Up By: morto1701@gmail.com - Sunday, Dec 07, 2014 at 22:04
Our secret Brian, what variant and year!
Thanks Morto
829184
Follow Up By: Member - Brian - Monday, Dec 08, 2014 at 12:25
Sorry Morto , seller told me that , didn't ask any further !
829205
Reply By: bluefella - Monday, Dec 08, 2014 at 10:47
Hi Morto
Have you considered having tours re upholstered, better padding etc. This way you would have exactly what you want.
542705
Follow Up By: bluefella - Monday, Dec 08, 2014 at 10:48
typo t===y
829196
