Thursday, Dec 18, 2014 at 15:32
Hi there. I was a bit confused as
Here's a copy of the instructions sent to me from Adele at Explore Oz
This was sent to me as I had a discounted $ for the 2015 update
Is that the 2015 update you are trying to do?..it takes a while to download all the updates..we had our Hema 7 pre loaded with EOTopo
"Hi,
Thank you for your purchase of the Hema Navigator 7 with EOTopo 2014 pre-loaded.
As you may be aware, we released the 2015 version of the EOTopo maps back in October, however due to several issues, we have, until now, been unable to provide an upgrade price and process for the HN7 devices.
This has now been resolved, and we are happy to announce that we can supply you with the new 2015 EOTopo maps on either SD, USB or via Download.
Simply go to this page:
http://www.exploroz.com/Shop/ExplorOz+EOTopo_200K.aspx
And go to Buying Options to add your preferred option to the
Shopping Cart, then enter the following code into the Promo Code field:
EOTopo Upgrade
This will reduce the price for the SD or USB to only $19.95 (plus $4.95 postage), or reduce the price of the Download to $10.45. *NOTE* you must be logged in for this promo code to work.
Once you have the maps, you will then need to transfer them to your HN7. The instructions on how to do this are found here:
http://www.exploroz.com/EOTopo/Help.aspx
(Just go to the EOTopo with Hema Navigator section for instructions)
If you have decided to purchase the Download option, you may want to view these instructions prior to download, as they will show you which maps you need to download (you only need certain file formats for use with the HN7).
If you run into any problems with purchasing or transferring the maps, please just contact me via phone or email (contact details are in my email signature below) so that I may provide further assistance.
Adele Scala
Customer Service Manager
Adele Scala: adele@itbeyond.com.au"
When you add it to your cart, the discount will be applied there.
Hope that helps....
It is a little confusing
Robyn
543120
Follow Up By: alhow - Thursday, Dec 18, 2014 at 17:17
Young Nomads,
Thanks for your reply. Due to your reply I went back through my emails and found the email sent by Adele in October that I hadn't even opened.
I'll follow the instructions and see how I go from there.
Al.
All done, thanks
Young Nomads.
Al.
830008
