Changing the seats in an 11 seater troopie
Submitted: Thursday, May 09, 2002 at 00:00
Ross
We are looking to buy a 6 seater troopcarrier (3 x 3 benchseats). We are seeing plenty that have a 3 or 11
seat configuration.
Does anybody have experience in modifying a 3 seater of 11 seater by adding a second row of bench seats behind the front ones in a 3 seater troopcarrier, or taking out the centre facing seats in an 11 seater and fitting
the bench seat behind.?
I have rung a couple of
seat fitting
places today who assure me it is not a problem, with a cost of about $1000 including fitting for the
seat and seatbelts. You apparently get an "ADR" approved stamping" and take the car to the RTA for an inspection....hopefully no dramas or major costs.
Also, one fitter noted that you need to ensure that the front passenger
seat can fold forward to give access to the rear seats.
Has anybody any first hand experience of this process??
Ross
Reply By: Ray - Friday, May 10, 2002 at 00:00
Ross, the reason you have not seen many of the 6 seaters as they came out as a special 75 series RV with stripes etc. Any of the bus companies will have
places that make the bus seats, or go to a conversion place where they convert coaster type buses to campers, they wilkl have seats that already comply available, They are two seats or single and could be fitted to the troopy
Ray
3443
Reply By: extroopie owner - Monday, Jun 24, 2002 at 00:00
I had a '93 model Troopcarrier (3 seater) which I had fitted with a
'Take 3' bench
seat behind the existing seating. This must be done by an authorised installer to obtain the appropriate Compliance Plate changes. One important requirement was that the front passenger
seat could be pushed forward by operating a modified lever accessed by people using the rear seating. There is no lever available on the market so I had to modify my own by reversing the original lever.
The original RV Troopcarrier passenger
seat (front) pushes forward and then swings towards the center. I removed my original
seat and fitted one of these RV seats and found it a big improvement. At a later date I then fitted 2 custom padded '75 series bucket seats and used the original modified lever protuding from the rear left of the passenger
seat. This still allowed adequate space to alight from the vehicle.
I also made a small checker-plate aluminium step using the
seat mounting points and the bottom
seat-belt mounting bolt (passenger side). This prevented people slipping on the sloped vinyl floor immediately adjacent the rear of the passenger
seat.
Something to be aware of is that three seater complianced Troopcarriers can never be fitted with the original side facing seats.
Hope this has been some help.
4394
