Cub Camper Trailer Rear Access Door
Submitted: Friday, Jan 02, 2015 at 11:07
adtrac
Set up the camper trailer last night to air out but in doing so I managed to destroy the rear access door in the process ,forgot to undo springs !
I wonder how others get on when setting up .
Reply By: Phil B (WA) - Friday, Jan 02, 2015 at 14:02
I've been lucky with
mine - 8 years.
I've often wondered how I would get on if
mine was damaged in set up.
Do CUB have spares?
543612
Follow Up By: adtrac - Friday, Jan 02, 2015 at 17:22
I have had my cub for 4 years now just got a bit complacent.
Cub probably do carry spares as I would expect this happened fairly often .
I would also expect the door to be expensive .
I will getting my local steel supplier to supply the replacement sheet cut to size and I will fold to match and fit to the hinged (WELDED)
and respray to match color myself .
Just another job to be done.
830620
Follow Up By: Shaker - Friday, Jan 02, 2015 at 17:55
Could be worth giving Cub a call, might be cheaper than you think.
830624
Reply By: Nomadic Navara - Friday, Jan 02, 2015 at 16:36
If you can find out how to read e-books you can try this
Cub Service & Repair Manual.
543621
Follow Up By: Frank P (NSW) - Friday, Jan 02, 2015 at 18:00
The link says it is a pdf download, so you probably don't need an e-Book reader to read it. Any computer, smartphone or tablet should be able to read it natively.
If you want, there are eBook apps which will allow you to import a PDF file and dress it up a bit to make it look more like a book.
830625
Reply By: Ozhumvee - Friday, Jan 02, 2015 at 19:07
We did that with our supamatic very early on and I just straightened it out in situ, always had a wrinkle but sealed ok.
found the best solution to doing it again was to put the wooden blocks for the rear legs just inside so that you had to open the rear door to get the blocks to put the rear legs down.
543624
Reply By: Member - Odog - Friday, Jan 02, 2015 at 19:39
We just brought some spares through cub, rang them on Saturday morning, received the bits about Thursday, we are near
Canberra , happy with the service..
Purchase was new mesh for the stone guard, and due to the stone chips on the draw bar a frame, got a set of cub stone flaps which hang off the stone guard... Will look pretty flash, when we get off the couch n put them on.. All up think about $300... Could have done it for less coin, but nice to have the original logo on the flaps... We are happy.. Cheers
| Some people want it to happen, some people wish it could happen, others make it happen! Lifetime Member My Profile Send Message |
543625
Reply By: Member - Keith A1 - Saturday, Jan 03, 2015 at 10:21
Hi Adtrac
We had an incident at
Wilson's Prom a couple of years back when a wombat got himself wedged under the back tailgate of our camper and in his struggles to free himself, lifted the whole door, including the stove and sink, off its hinges.
We were asleep inside at the time but the noise was pretty impressive and we scampered outside to find the door lying on the ground. Fortunately we were able to get it back on but learnt a lesson about not closing it at night. Particularly down there.
543653
