Friday, Jan 02, 2015 at 13:32
Firstly a USB drive is not the same as a Zip Drive which used discs and normally got the rattle of death in a short time.
Some call USB drives Zips I guess but they are quite often called PEN drives or USB stick drives.
Up to 32 gig they can be formatted in either NTFS or Fat32 which is the normal way.
Above that they are EXFat which is different and can be a problem if device only reads Fat32. They are not normally encrypted unless you do it yourself.
You can format a 64G pen drive in Fat32 by using various software programs, one being GUI format. I use one in a dashcam which can only read Fat32 and had to reformat the 64G card with the above program.
It now works properly.
I have a 32 g SD card in my car stereo and it has 6,000 tracks on it and uses less than 18gb so you would never need a 64g USB Stick unless you were going to travel nonstop for the rest of your life LOL
830601
