Mechanic Adelaide
Submitted: Friday, Jan 02, 2015 at 14:08
Cat L
Hi all, I'm looking for a reliable mechanic in
Adelaide to look at my 2003 Navara STR 3L diesel - had the head gasket replaced up in
Roxby Downs a few months ago and when I got the car back it had an issue with what in assuming is a
fuel pressure problem - the car starts but then cuts out a few seconds later. If I pump the
fuel pump with the hand primer and rev the car when I restart it then it generally starts ok again. But now it's starting having issues while getting up to speed - particularly at high speeds - it loses power and stutters and jerks when accelerating. Any suggestions are much appreciated!
Reply By: Cat L - Friday, Jan 02, 2015 at 14:11
Should also add - I took the car back to the Roxby mechanic a few times to get them to sort out the issue but had no luck. They replaced the
fuel pump but that didn't fix the problem and they basically washed their hands of the issue.
543613
Follow Up By: Skippy In The GU - Saturday, Jan 03, 2015 at 13:22
if that roxby mechanic is Raa approved you could contact the RAA in
Adelaide and have them help you getting it fixed, the roxby guys should get the bill
830673
Reply By: Peter_n_Margaret - Friday, Jan 02, 2015 at 17:13
I have used Saint Marys Auto Repairs for 15 years.
It is a family business south of the city.
http://stmarysautorepairs.com.au/
OKA196 Motorhome
543622
Reply By: PhilD - Friday, Jan 02, 2015 at 20:16
I suggest you talk to the guys at Cross Country 4x4 on South Road at Edwardstown 83575993. They know Nissans.
543628
Reply By: Buff - Saturday, Jan 03, 2015 at 13:17
Hi Cat,
I'd recommend Detract Diesel, at 8 Quinlan Ave, St Mary's...Jeff and Chris are good blokes, and have solved a few tricky issues for me over the years. Excellent service and communication during each job, and I have always felt that their prices are fair.
http://www.detrac.com.au/Home
543664
Reply By: Rick (S.A.) - Saturday, Jan 03, 2015 at 17:48
Try the 4WD experts, Alltrac, at South Rd, Mile End
Yes, I'm a biased, satisfied, repeat customer
543680
Follow Up By: Member - Andrew & Jen - Sunday, Jan 04, 2015 at 12:29
I would second that recommendation.
Brad and Mark run a good business and back their work.
If they make a mistake (rare), they fix it at their cost with no argument
Andrew
830718
Reply By: Member - Charlie B2 - Wednesday, Jan 07, 2015 at 21:34
Hi Cat L,
I realise this post is now quite a few days old, so you may have already made a decision but, just in case you haven't, you might like to try All Wheel Drive Repair
Services (
Howard 0418 844 795).
Howard has been doing all my maintenance and repair work since 1989.
Sure, I've got a 'Cruiser but he does quite a bit of work on Nissans.
Your call !
Charlie
543889
