Sunday, Jan 11, 2015 at 01:59
I took on a job of driving an old - no ancient - Commer Knocker from
Geelong to
Norseman in Dec 1995 for a bloke from
Norseman.
I'd bought a little Inter truck (a D1310) off the same dealer, so it was easy enough to load the Inter onto the back of the Commer.
My heart sank when I first saw the Commer. It hadn't moved in probably 18mths, and the spiders owned the interior of the cab.
The scrap yard dealer assured me it was a beauty, and it ran like a Swiss watch, and he'd drive it to
Brisbane himself tomorrow.
It was registered and had passed its pink slip inspection no worries, he reckoned.
It was about then that I found the entire roof was held on with duct tape, painted over!
The scrappie said he'd have to find the battery for it. He actually went off and found a battery that would have normally been scrapped, I'm sure.
It did actually crank the old Knocker into life - but I think that was more because there was very little compression in the motor.
When
the Knocker cranked up, we couldn't see half the yard for blue smoke. I dutifully loaded the little Inter on the back and set off. Looking behind me, I still wonder to this day why the fire brigade wasn't following me, the volume of smoke looked like
Geelong was under threat from a bushfire!
About 30kms out of
Geelong, I blew a front tyre. Sure enough, there was no spare, no jack and no wheelbrace. I rang up the dealer and he very promptly delivered a better (inflated) spare wheel - in the boot of his Mercedes, no less.
I reckon he would have delivered a boot load of cow manure if it meant he never saw the Commer again.
We changed the wheel (he'd been thoughtful enough to bring a jack and wheelbrace) - and I was off again.
I actually got to near Bordertown as dusk fell, and I went to switch on the lights. Yep, you guessed it, the Prince of Darkness ruled.
I had nothing by way of lighting - no parklights, and no headlights. I wasn't going looking for the problem/s with dusk rapidly falling.
I ran her into Bordertown and stopped her outside the pub as it was getting completely dark.
I went to move her off the main street 10 mins later, and she refused to start. Luckily the pub had a room, so I was set for the night.
The Commer stayed parked in the main street overnight.
Next morning, I went out, put about 2 litres of oil and about 4 litres of
water in her, and she cranked right up, and off I went.
Somewhere West of Bordertown the roof started flapping in the 85kmh (top speed) breeze.
It got worse and worse, and it threatened to turn the Commer into the full sunroof model, as a frighteningly huge gap opened up, at the front and sides of the roof.
I had brought a small pair of pliers, so I stopped, pinched some fencing wire, punched holes in the roof and the cab at all 4 corners, and wired the roof back on.
Off we went again. Suddenly, near
Murray Bridge, I started losing air pressure.
I pulled into a garage and the mechanic was eager and on the ball, he found a chafed airline and patched it up. We were on the road again.
I made it through the
Adelaide Hills, taking a shortcut North to avoid
Adelaide itself.
I got to a point probably 10 or 20kms East of
Nundroo before night fell that second day.
I was smart enough this time to pull off the road before it got dark, so I didn't need those non-functioning lights.
I found a
gravel pit about 250M off the highway and camped for the night. However, during the night, a cold front rolled through, and the overnight temperature dropped to about 3 degrees (even though it was mid-December!)
There was no way the Commer would start the following morning. I had very little by way of
tools and equipment, just a few basic items that I could carry on the plane, besides my sleeping bag and pillow.
So, I rounded up some more fencing wire and twitched it together to make a rudimentary set of jumper leads.
Some judicious work was required to insulate them anywhere they touched metal.
I connected them to the Inter and started the Inter up and let her run for 25-30 minutes. After that length of time, there was just enough juice in the Commer battery to get her started. Another 2 litres of oil and 4 litres of
water, and we were set.
I hit the road again and made it to about 400kms East of
Norseman, when the air compressor failed.
The air pressure dropped and the maxi-brakes on the back axle locked on.
I'd just passed an MRD
camp, so I walked back, borrowed a big shifting spanner off the blokes there, and backed off the maxi-brakes until the brakes released.
I returned the shifter, and high-tailed it for
Norseman - with no brakes whatsoever.
Luckily, the traffic was light and I had no real need for brakes.
About 4:00PM, I reached the outskirts of
Norseman. I slowed down and found another
gravel pit with a handy pile of dirt that I could use for a ramp.
I backed up to the pile of dirt, stalled the Commer and chocked the
wheels with rocks and proceeded to unload the Inter.
This proceeded without too much drama and I drove the Inter into
Norseman to find the bloke who owned the Commer (he was the Shire mechanic and he'd knocked off for the day).
I found him without too much trouble, and told him I'd delivered his Commer, and it was ready to be picked up from the
gravel pit - but it did have some air and brake problems!
He was very surprised that it had been driven to
Norseman - he'd only bought it as a farm hack (because it had a Hiab crane on it) - and he thought the dealer was going to deliver it on the back of a semi!
I collected my $1300 from him for the delivery, and left him with it, and drove the last leg back to
Perth in my little Inter.
He did tell me later, he'd spent 4 days steam-cleaning the truck engine, drivetrain and chassis, just so he could work on it and actually find components!
He found the air compressor failure was merely a broken disc valve in the compressor, and he was pretty chuffed with the Commer, because it was just what he wanted for the farm!
I have to say this was one of the more "interesting" trips I've done, and I reckon I earnt my delivery money! I did also save quite a few hundred bucks in
fuel for the Inter.
Then, just 5 years later, someone stole the Inter, and I've never ever seen her again - but that's another story!
Cheers, Ron.
544052
Follow Up By: Bigfish - Sunday, Jan 11, 2015 at 08:52
Good story Ron. Wish my memory was as good..lol
831165
Follow Up By: Allan B (Member, SunCoast) - Sunday, Jan 11, 2015 at 10:27
Awesome Ron. I can see the whole event in my mind's eye.
831170
