Old Electrolux Gas only fridge
Submitted: Wednesday, Jan 14, 2015 at 07:58
Treading Lightly
Hi guys,
A mate of
mine has recently come across a very old Electrolux gas only fridge, and has no ideas as to performing the lightning procedure, as the "burner" is right at the rear far LH corner and has very limited space was there a lightning procedure or other equipment. From what I can see there appears to be some sort of "rail" or guide underneath and heading towards a burner.
I am sorry but there doesn't appear to be a model number, it is approx. 500mm square, dirty yellow in colour , and has a Temp control in the LH Rear corner.
JD
Reply By: Wayne's 60 - Wednesday, Jan 14, 2015 at 10:10
Hi JD,
I'm not sure if the following information will help.
The
Vintage Caravan Forum has a post about half way down the page. There is discussion about lighting a gas only fridge by lighting a wick and pushing it along a rail.
Hope that this helps a little.
Wayne & Sally.
544220
Follow Up By: oldtrack123 - Wednesday, Jan 14, 2015 at 14:26
Yes
A wick of asbestos string was the way
It was soaked in metho, then pushed in under the gas burner
Held there until gas ignited then for a bit longer [about a minute to ensure the flamefailure valve had opened
If pulled out too soon the gas would shut OFF
831342
Follow Up By: Bob Y. - Qld - Wednesday, Jan 14, 2015 at 16:53
TL,
I've used a piece of Chux, in lieu of asbestos, in the manner described by OldTrack. Doesn't last as long as asbestos, but is easier to procur. An off cut of asbestos would be difficult, if not impossible to purchase.
If the gas flame won't stay alight, you may need a new thermocouple. They sit there, with their willy in the flame for days, and months, and eventually cease to function. You didn't hear this from me but you can use a small piece of thin wire, like fuse wire, to keep the valve open, to keep the gas flowing while you see if the fridge does get cold. Not wise to do this permanently!!!
831362
Follow Up By: Member - Tony F8 - Wednesday, Jan 14, 2015 at 19:16
Firstly before even thinking about trying to light it, I would be having inspected by a certified gasfitter, who knows what the o rings etc would be like.
831371
Reply By: Treading Lightly - Thursday, Jan 15, 2015 at 09:42
Thanks for all your replies, the Vintage Caravan
Forum was a real eye opener.
JD
544305
