How do I load etopo from an Sd card to my Hema 7
Submitted: Friday, Jan 16, 2015 at 18:09
Bigfish
Have a new hema 7 I was given for Xmas and I have purchased the etopo200k sd card with maps on it. I have absolutely no idea on how to put these onto the hema 7 and the exploreoz it team is not answering the phone.
Can anyone help ?
Reply By: The Explorer - Friday, Jan 16, 2015 at 18:17
Simple explanation - Assuming you have an SD card reader in PC/Laptop?
Copy the relevant files from the EO SD card onto your PC/laptop and then copy these to the Oziexplorer "Maps" folder on the microSD card that is in your HN (remove micro SD from HN, put it into micro sd card adapter that should have been included in package, then slot this into SD card reader of PC/Laptop).
544382
Follow Up By: Bigfish - Friday, Jan 16, 2015 at 18:53
Thanks mate. Worked a treat. The sd card that came with the hema is 8 meg. Already got about 4 meg of maps on. The
eotopo had 13 gig of maps. I just selected the main Aus one as a trial.
831486
Follow Up By: The Explorer - Friday, Jan 16, 2015 at 19:11
No worries
Yes you may need to invest in a larger micro SD. You can never have enough maps :)
831489
Follow Up By: Bigfish - Friday, Jan 16, 2015 at 20:06
Yep...off to office works tomorrow for a 32 gig..
831497
Follow Up By: ExplorOz - David & Michelle - Friday, Jan 16, 2015 at 22:03
Use the sd that
EOTopo comes on. Firstly backup the files to your pc then copy the hema sd to the 16gb card and then copy the ozf files from the backup to the 16gb card. You do not need all the files just the ozf ones for the hema unit.
831526
Reply By: JohnnyC - Saturday, Jan 17, 2015 at 09:45
Hi Bigfish, I'll give you a tip.
Put the original HEMA SD card away or make a copy in case anything goes wrong.
My Hema has had a hiccup on powerup, twice now which has corrupted the SD card, it cost me $100 to get a new one.
I suspect it's related to the auto powerup and power interruption when I start the engine, it gets a short application of power when ACC comes on, off whilst starting engine and on again when engine starts, Hema doesn't like it if its internal battery is flat.
Disabled auto powerup, fixed the problem.
544406
Follow Up By: Bigfish - Saturday, Jan 17, 2015 at 10:21
Thanks Johnny. That is exactly what I did 1/2 hour ago. I,m not up to speed with the different file associations. I am going to buy 16 gig micro sd card and load all my maps onto that then hang on the
eotopo and the hema sd cards.
cheers mate.
831539
