sub tank light in 2004 diesel patrol
Submitted: Monday, Feb 02, 2015 at 16:07
fence
sub
tank is lit up on dash and the
tank won,t transfer
fuel. Book says go to Nissan.
Does anyone have any suggestions.
thank you bruce.
Reply By: Tim F3 - Monday, Feb 02, 2015 at 16:40
i would check the earth wire on the
fuel transfer pump.
545238
Reply By: Lostkiwi - Monday, Feb 02, 2015 at 16:56
Had a 2.8 GU for 10 years. Light staying on seemed to occur if sub-
tank was left empty for some time. Remedy, disconnect battery for a few minutes and bingo.
Hope it works for you.
B
545241
Reply By: Michael ( Moss Vale NSW) - Monday, Feb 02, 2015 at 17:51
I had the same the problem with my first GU, it was the transfer pump. cost about $700 with labour! Try disconnecting the battery for a few minutes and check all your fuses before you try your Nissan dealer! Michael
545246
Follow Up By: bruce b2 - Monday, Feb 02, 2015 at 18:13
especially reply number 1, replies 2 and 3 are also worth a try.
bb1
832780
Follow Up By: fence - Monday, Feb 02, 2015 at 20:13
Thank you for the info. Will try all tomorrow an let u know how i go.
chow.
832785
Follow Up By: Bonz (Vic) - Tuesday, Feb 03, 2015 at 17:16
If it is the transfer pump there are much cheaper alternatives for replacement than Genuine Nissan.
832835
Reply By: duck - Monday, Feb 02, 2015 at 20:41
It's common just disconnect the battery for few mins and then reconnect & all should be fine
545251
Reply By: Member - Stuart P (WA) - Tuesday, Feb 03, 2015 at 08:55
try the battery disconnect first
545268
Reply By: fence - Tuesday, Feb 03, 2015 at 11:11
Thank you from the bottom of my sub
tank.
Disconnected battery for 10 mins reconnected it and all is FANTASTIC.
I was not looking forward to going to Nissan and an auto elect said would take half day to take out dash and reset the module.
Thank you all,
bruce.
545277
Reply By: Gary T7 - Tuesday, Feb 03, 2015 at 16:44
