Caravan from Normanton to Booroloola
Submitted: Thursday, Feb 12, 2015 at 12:41
oleliste
Can we travel with a caravan from burketon to booroloola in May?
Reply By: Member - Rosco from way back - Thursday, Feb 12, 2015 at 15:11
Should not be a problem. We were up that way around then last year and it was your typical gravel road with the odd rough patch here and there, but basically OK.
545772
Reply By: Member Ray M (QLD) - Thursday, Feb 12, 2015 at 16:57
If we get a late wet up here like it looks like at the moment, then you will have to check first. I went that way in April last year and had to wait for the road to open as the rivers were up. You should however be ok by May
545782
Reply By: Member - Stuart and Gunny - Thursday, Feb 12, 2015 at 18:45
If your going via
Savannah Way you would need an of road caravan.I travelled that way mid September and it was corrugated for some long sections but all the rivers were low.
545786
Follow Up By: Member - rooster350 - Saturday, Feb 14, 2015 at 09:11
We were along there year before last and our poptop is not an off roader ,sure it was rough in
places but if you take it steady and try not to break any speed records you should have no trouble.
833557
Reply By: Member - Beatit (QLD) - Thursday, Feb 12, 2015 at 20:04
G'day Ole,
We did the trip in September 2012 and had no problems but as has been pointed out earlier it is all about the weather at the time.
Please see our blog
To Manangoora
Kind regards
545794
Reply By: Member Andys Adventures - Thursday, Feb 12, 2015 at 20:20
Hi oleliste,
You will be fine in May. The wet season is poor this year with low rainfall, only 100mm at Lorella Springs last month.
I find May the best time to travel those roads, before they get chopped up.
Cheers Andy
545798
