Comment: EOTopo Downloads
Submitted: Tuesday, Feb 17, 2015 at 09:11
DDCman
I've been trying to evaluate the topo maps. I downloaded the 250K free topo map and the android Oziexplorer app running in trial mode. Oziexplorer doesn't recognize the map (.ozf4 format). Oddly, I downloaded the Memory Map app, and it recognizes the .ozf4 map and works fine! I did download the MM version of the 250K map, but hadn't put it on my tablet (Samsung 10.1 2014 edition), so it is definitely using the .ozf4. Reluctant to spend the bucks if silly things happen at the trial stage.
Graham
Reply By: Member - Alan H (QLD) - Tuesday, Feb 17, 2015 at 09:41
I have (along with many others) put OzTopo on Oziexplorer on Samsung tablets and it works fine. The map comes with an ECW format as
well as ozf4.
Can't think what your problem maybe but I can assure you that it will work fine.
546073
Follow Up By: DDCman - Tuesday, Feb 17, 2015 at 09:50
Yes, if others were having problems, there would be more than just my post. Oziexplorer works with the .map version no problems, but when I go to the DIR with the .ozf4 map, it doesn't even show it as being there. A puzzle. Thanks Alan.
Graham
833760
Follow Up By: DDCman - Tuesday, Feb 17, 2015 at 10:05
Oops, got it to work. Seems you need the corresponding .map file as
well as the .ozf4 file.
Graham
833763
Follow Up By: Member - Alan H (QLD) - Tuesday, Feb 17, 2015 at 10:58
Yes
Best to keep the two files together in the same directory
Glad all is
well
833766
Follow Up By: Member - Munji - Tuesday, Feb 17, 2015 at 17:03
Not wanting to hijack the thread peeps
I purchased the
Eotopo USB for a Samsung Tablet 8 however it does not seems to want to work.
I since downloed oziexplorer but still no success.
Has anyone else had the same problem?
Cheers in advance
833789
Follow Up By: Frank P (NSW) - Tuesday, Feb 17, 2015 at 17:18
Munji,
The tablet cannot see the USB stick as a drive or expanded memory. You need to install the Android version of Ozi Explorer onto your tablet, then transfer the files on the USB stick to Ozi's MAPS folder via a PC. You should be ok then.
833791
