Comment: Explaining Smart Charging?
Submitted: Monday, Sep 28, 2009 at 03:04
ThreadID: 111883 Views:1348 Replies:0 FollowUps:0
Hi Again DandJ
The Sterling AVR 12 has three programmable battery settings and the type is indicated by the LED colour.
Open Lead Acid LED yellow. 14.8V @ 20oC
Gel Exide Specs LED green. 14.4V@ 20oC
Sealed AGM LED red. 14.1V@ 20oC
If you undo the four screw and remove the cover you will find some dip switches that allows you to set the relevent battery type charging parameters.
For the top volt dipswitch (1) awayfrom 1 (2) to 2.
For the next volt down dipswitch (1)to 1 (2) away from 2.
For the low setting dipswitch (1)away from 1 (2) away from 2.
Ian
