Comment: Navara Drawers
Submitted: Wednesday, Jan 27, 2010 at 10:20
porlsprado
Hi Mark
Hi Mark
Re: the tubular frame, did you have to weld those connections or is that a saw off to fit and attach modular type snap on frame thingo?
thanks
Reply By: Deleted User - Wednesday, Mar 04, 2015 at 00:55
i cut the frame with a metal drop saw and those connectors just tapped in ( with a little Inox sprayed on them for lubrication).you could if you wanted to pop rivit the connectors in but so far i've had no trouble with them working loose.
547202
