Steering shudder
Submitted: Saturday, Mar 13, 2004 at 16:20
Bob et Joëlle
We have a 100 series turbo diesel landcruiser - still using the factory tyres but not original. 80,000 kms and have a steering shudder at about 100-110kms per hour. Have had the
wheels rebalanced and the alignment checked. Mostly highway driving - a bit off-road but nothing very violent. Any ideas anybody ?
Bob and Joëlle
Reply By: Member - Noel C (VIC) - Saturday, Mar 13, 2004 at 16:26
Check the brake disc for warping. If you've crossed streams with hot discs and pads the warppng effect can cause considerable shudder.
50187
Follow Up By: Bob et Joëlle - Saturday, Mar 13, 2004 at 16:41
Thanks Noel
The problem doesn't appear under brakes - only travelling in a nice straight line on the freeway ! Will check it out though.
B &J
312006
Reply By: Kev - (Cairns,QLD) - Sunday, Mar 14, 2004 at 21:06
Sometimes tyres change to an egg shape instead of being perfectly round when they have done a few km.
This will cause a wobble at speeds. Why this can happen i dont know.
The factory tyres are not thre greatest tyres around & considering they are already at 80,000km id suggest a new set would be on the cards.
If not wanting to renew your tyres try borrowing a set of a mate maybe & see if the problem is still there.
Kev.
50326
Reply By: bob - Sunday, Mar 14, 2004 at 21:42
I had an FJ40 years ago. Same problem (but it was at 80kph+).
Well known brand of tyres, supposedly balanced, were 6mm out of round when checked with a dial indicator while vehicle was jacked up. Tyre dealer took some convincing but replaced them. Problem fixed!
Anything more than 2-3mm out of round will cause havoc at high speed.
You don't need a dial indicator. Jack up vehicle until wheel just clears ground, spin wheel by hand and observe gap between tyre and ground. $200 tyre - expect perfection!!!
50330
