2H Diesels
Submitted: Sunday, Mar 14, 2004 at 10:04
CHRIS
Have noticed on a previous post that the 1 hz has oil galleries in the engine for cooling. Have been led to believe by a mechanic that the 2H is the same, can any one enlighten me as to whether this is in fact true.
Reply By: Phil G - Sunday, Mar 14, 2004 at 11:10
Yep, its a true fact! 2H and 12H-T are the same in this respect.
50280
Reply By: Davoe - Monday, Mar 15, 2004 at 12:39
There is a side plate on the motor that allows the coolant to flow out of the motor and around a heat exchange plate that the oil flows thru. The oil filter assembly bolts onto this sideplate 3-4 hundred to replace not including the heat xchange plate
50380
Reply By: CHRIS - Tuesday, Mar 16, 2004 at 04:14
Thanks for your prompt answers fellows.
50487
