GU 4.2 Patrols - Warranty and aftermarket accessories
Submitted: Monday, Mar 15, 2004 at 10:36
ThreadID: 11253 Views:3120 Replies:7 FollowUps:10
Howdy,
Fairly new to this scene, really enjoying the read!
I've got a fairly detailed question (in my eyes anyway!). In the market for a new GU 4.2 Turbo Patrol. Currently own a 90 4.2 diesel GQ aftermarket turbo 4inch kit with all the bells with only 180k's on it. What is everyone's experience with the 4.2 Turbo Diesel re: drivetrain etc and if I was to have 4 inch kit, and 33's fitted to it, would it cancel my warranty. Further can you fit the upgrade computer and keep warranty plus ie. powerup from Brisbane Turbo and exhaust and keep warranty or would that void it? Would it be worth while keeping the GQ if the experience with GU 4.2 TD isn't that good? Anyones input is valued.
Trol
Reply By: Michael - Monday, Mar 15, 2004 at 11:23
Hi There, I dont know about the rest of the questions but 4.2 tdi doesnt have a computer as such, the only thing controlled is the EGR valve, the rest is totally mechanical . The way to go for reliability !!!!! Cheers Michael (4.2TDI owner)
AnswerID: 50373
Follow Up By: Trol - Monday, Mar 15, 2004 at 11:45
Michael,
Sorry guys, meant to post follow up. Have you done many k's in your's to date? Fuel economy etc?
Cheers!
Trol.
FollowupID: 312169
Reply By: Trol - Monday, Mar 15, 2004 at 11:43
Michael,
Cheers!
Trol.
AnswerID: 50374
Reply By: Michael - Monday, Mar 15, 2004 at 11:52
Hi Trol. 50,000KM,s six months old 4.2 Tdi getting about 12 litres per 100k's, thats driving Moss Vale ot bankstown daily on freeway, our other GU, series 2, 4.2 Td gets about 11 litres per 100 doing same thing, 300,000ks , 4 1/2 years old and still going strong. Ony 1 mechanical problem in all those 300,000 ks, front hub covers cracked,$500 a side, with very little heavy off road. cheers Michael
AnswerID: 50376
Reply By: Roachie - Monday, Mar 15, 2004 at 12:41
Trol,
As far as I know, a manufacturer has to be able to demonstrate that the modifications you've done to the vehicle have led to the fault occuring. So, for example, if you had the power-up modifications done and then blew a hole in a piston or the fuel pump went "physssssst", then they could argue that you helped cause the problem.
However, if you had all that stuff done and then the electric window mechanism went on holiday, they couldn't argue you'd caused that by what you'd done.
Just my opinion.....and then it starts to get all mirky.....like what happens if you start to over-heat?.......or the bigger tyres could be said to contribute to premature wear in the steering and brake department etc.
I have a 2000 4.2 t/d and have it fairly modified too. The only warranty work I needed to have done was at Nissan's own recommendation and that was to replace 5th gear before it let go; but they've fixed that on the newer models so I believe.
Great truck, you won't regret buying one.....obviously you've had a good run out of the GQ and it is barely run in. You could certainly do worse than to hang on to it if it's going okay.
Roachie
AnswerID: 50381
Follow Up By: Trol - Monday, Mar 15, 2004 at 12:52
Hi Roachie,
Thanks for that! How many K's had you done before 5th gear let go? Is this a problem in the 4.2 TDI?
I guess that mods are something I could chat to Nissan about and get them to put their confirmation of a mod in writing...
Trol.
FollowupID: 312173
Follow Up By: Roachie - Monday, Mar 15, 2004 at 14:17
Trol,
My 5th gear hadn't actually let go. I was lucky in a way. This is what happened.....I ususally do all my own services. When I moved over to SA from NSW in late 2002, I couldn't bring all my gear (ramps etc) ; so I booked the Patrol into the Nissan place to have a oil change done. When I went to pick it up, the service manager asked whether I'd had any trouble with 5th gear. They checked the gearbox oil level as part of their service proceedure and found it to be coffee coloured, which he said was a sign the no.5 cog was on it's way out. He actually offered to have it done under warranty, with about 85,000klm on the clock. I've now done over 116,000klm and no worries.
As I said before, they've known about this problem for a few years and the Patrols made over the last few years have had the stronger cog in them from new, so the 4.2 T/Di won't have that problem.
Roachie
FollowupID: 312182
Follow Up By: sensei - Monday, Mar 15, 2004 at 15:19
Roachie,
Did nissan tell you to change 5th gear before it let go? my dealer up north told me they will NOT replace 5th gear until it lets go. I have a 2001 4.2 patrol and have been keen to get it replacement before its destroys it self. I might have to have another word with my Nissan friends..hehe
FollowupID: 312190
Follow Up By: Roachie - Monday, Mar 15, 2004 at 15:33
Sensei
No, they didn't "tell" me to get it changed...........they "offered" to change it for me under warranty....how could I refuse?
He reckoned it would be about $3,500- to get it done outside warranty. He tried to get me to take out an extended warranty for about $800-, but being a bit of a gambler, I declined.
They had the truck for 2 days and showed me the parts they took out. They replaced 5th cog as well as the main shaft. There was a helluva lot of slop between the two. It is actually the inside spline on the 5th gear that was giving up the ghost, not the outer large teeth. I think Nissan had tried to save a few dollars by skimping on the length of the spline, which had put too much stress on the parts.
Roachie
FollowupID: 312191
Follow Up By: Member - Ray - Monday, Mar 15, 2004 at 19:11
Roachie,
Could you let me know the name of the dealer that replaced you 5th gear as I have asked here in Perth and they told me Nissan will only do it when the box goes bang.
I have done almost 80 000 and am on my way up north soon so am a bit concerned it may die on me.I will have a go at Nissan if I can get confirmation from the people who did yours. PM we if you like.
Thanks. Ray
FollowupID: 312225
Follow Up By: Roachie - Monday, Mar 15, 2004 at 21:52
Ray,
The local dealer here is Gunnings Motors, 5 Taylor St, KADINA, SA, 5554
Phone: 08 8821 1022
I can't recall the name of the service manager, but I'm sure it's still the same bloke there now who organised my repair.
Good luck mate,
Roachie
FollowupID: 312248
Reply By: Rosco - Bris. - Monday, Mar 15, 2004 at 13:55
Trol
Get it in writing from Nissan, what effect (if any) it will have on your warranty ..... not the stealer.
AnswerID: 50391
Follow Up By: Trol - Monday, Mar 15, 2004 at 15:04
Rosco,
Thanks for your help, will take that into consideration.
Trol.
FollowupID: 312187
Reply By: pathfinder - Tuesday, Mar 16, 2004 at 13:50
keep the GQ - 180Kk? plenty of life left...
AnswerID: 50527
Follow Up By: Trol - Tuesday, Mar 16, 2004 at 16:56
Pathfinder,
Is that from experience? I have had a 25k offer for trade up on GU. Really appreciate it.
Chris.
FollowupID: 312348
Reply By: pathfinder - Tuesday, Mar 16, 2004 at 17:04
if you can get $25K changeover deal, then probably worth considering. However, I would have thought your current GQ with aftermarket turbo would make more power than factory TD, so why change? What's wrong with your current car/truck?
AnswerID: 50547
Follow Up By: Trol - Tuesday, Mar 16, 2004 at 17:16
Yes, it does, puts out 110kw at the wheels with only 12psi, substantially more than the GU. However have come into some money, and feel that an upgrade whilst the GQ still has 'young legs' may be more commercially viable for me. Nothing wrong at all with the Patrol GQ, no rust, it runs like a dream and knocks most TD 4WD's off the line pushing the big 33 MTR's. Love driving it but would also would like to drive a new truck with the mods with zero k's. I must admit, I've read a couple of previous forums on the TDI GU and it has put me off a little.
FollowupID: 312353
