Comment: Arrived at Wiluna
Submitted: Friday, Jul 09, 2010 at 23:09
ThreadID: 112754 Views:1382 Replies:0 FollowUps:0
yes Kev - we did cover that distance exactly. The reason for the difference between the two device trackings is that when in service, the iPhone is continually tracking so it gives an accurate snail trail following the path driven. The Spot service however only sends position data periodically - on the spot site it doens't even connect the dots, but just gives pinpoints for where you are (every 15mins I think). When using a Spot device through EOTrackMe the EOserver grabs the spot positions every 20mins and draws straight lines between the last position and the next position. Hope that clarifies.
MM
