waeco cf-50 no manual
Submitted: Tuesday, Mar 16, 2004 at 00:23
ThreadID: 11278 Views:6887 Replies:5 FollowUps:5
I have just bought a second hand cf-50 in good condition, but there was no owners manual. What is the significance of the LOW, MED, HIGH settings?
Billb
Reply By: Macca1 - Tuesday, Mar 16, 2004 at 01:22
See post 10579
Macca
AnswerID: 50478
Follow Up By: Well 55 - Tuesday, Mar 16, 2004 at 11:47
Cold - Colder - Coldest. hope this helps.
FollowupID: 312314
Follow Up By: Member - Moggs - Tuesday, Mar 16, 2004 at 20:06
Nup, don't think it will as it is wrong :)
FollowupID: 312373
Reply By: Member - Toonfish - Tuesday, Mar 16, 2004 at 02:03
any questions?
AnswerID: 50481
Reply By: William - Tuesday, Mar 16, 2004 at 04:29
Those settings are compressor speed RPM settings.
In summer MED will be sufficient and in winter LOW.
Only if you filled up the fridge with all warm goods would you run it on HIGH for a couple of hours.
Make sure you wire the fridge in with 6mm2 wire and do not use a cigarette lighter plug. Use a Hella 16mm DIN plug or Clipsal T plug and socket.
AnswerID: 50488
Follow Up By: Member - Moggs - Tuesday, Mar 16, 2004 at 08:23
No they are not.......they are to do with cut-out battery protection, being low, medium or high protection. Don't have the exact voltage cutout for each setting however it is in the manual
FollowupID: 312287
Follow Up By: bruce - Tuesday, Mar 16, 2004 at 09:06
There is nothing wrong with using a cig. lighter plug..that is what they come supplied with...ours has been working quite well with that plug...the old saying ..if aint broke , why fix it ?...
FollowupID: 312294
Follow Up By: pathfinder - Tuesday, Mar 16, 2004 at 12:15
it may work ok from cig lighter connect, but will definitely work better with some decent wiring direct to battery...
FollowupID: 312318
Reply By: Member - Peter K (NSW) - Tuesday, Mar 16, 2004 at 06:49
Billb
The owners manual can be downloaded, but I had a look to find it again but couldnt.
However the following link answers the question:
http://www.portable-engel-chescold-more.com.au/WAECO/faq3.htm
AnswerID: 50490
Reply By: Member - Steve - Tuesday, Mar 16, 2004 at 23:42
The low setting will cut out the compressor when the voltage is at 10.8 vlt at the pump. Not the battery. The pump has this built in. The low setting was designed to cope with the voltage drop over a cig lighter. You will however get 5-7 hours more running time out of a battery if you wire a 6mm loom from a battery.. The high cut out is 11.9 vlt cut out. Pointless really. cause your always using your second batery, right ?. If not use the high setting so you can start the car again.
AnswerID: 50631
